Admin problems please help me
CraigsUsername
i cannot use task manager ive looked for solutions and they say run regedit but it has been disabled by admin i am running vista home premium so i have no gpedit i used the command prompt in adminstrator mode typed in wscript.exe reg_enable.vbs after i download it and i did the step b4 that i 4got it and it said completed and they said it should work after and it didnt now i also have an unknown USB that keeps popping up i have no idea if that has anything to do with it and i have a virus that i can get rid of but it keeps coming back called mal/generic-A i installed the newest spysweeper that i bought from bestbuy and heard that it has better ratings then norton
someone please help me much apprecieted thx
From PM said:
the solution you gave me did not help because of my regedit is disabled as well so i cannot use regedit to enable task manager i run vista home premium so i dont have gpedit or w/e msc i recently have a virus that i dont know how to delete called mal/generic-A and my computer keeps saying i have an unknown USB in port 4 but thers nothing ther i dont know if all this ties in to my problem and help is much appreciated, my anit-virus software is spysweeper that i bought from a bestbuy thx
No Problem Craig,
See if Method Three in this tutorial below will allow you to enable regedit again so that you can enable Task Manager with the other one.
http://www.vistax64.com/tutorials/116415-regedit-enable-disable.html
Spy Sweeper is just a anti-spyware program and not a antivirus program. You can use the free Avast Home Edition antivirus program to run a very thorough scan after updating it's definition files. Hopefully it can remone that Trojan for you. If not, formatting the hard drive and doing a clean reinstall will.
i had the same problem, it is a virus that usually but not always blocks the run command, the folder options, cmd, task manager and regedit...
took a while to recover from it too since regedit was blocked... but regedt32.exe works fine so you can access the registry from there...
  • Memory
    2GB RAM
    ATI Mobility Radeon X2300
