Admin Problems
pogo25pogo
I am the owner and sole user of my computer.
I want to install a new program.
When I try to install it, I get a message telling me the administrator does not want me to install it.
What can I do to override this and install the program I want? pogo25pogo
Welcome
Several things to try. The first thing I would try is the hidden administrator. Give that a try.
http://www.vistax64.com/tutorials/67567-administrator-account.html
The hidden adminstrator is the most powerful and the true adminstrator. Do not use on a daily basis.
You can, also, try right click on program and run as administrator. This can be done by saving to the desktop, first.
I think, however, that the true administrator will solve the problem.
Hello Pogo,
Rich is absolutely right....you can try several things.
first try try to install the drivers using administrative privileges.
1. Right click on setup file, go to properties.
2. Click on Compatibility tab, then choose "Run as an administrator" under "Privilege Level"
Second what i think this may be due to corrupt user account. You may also create a new account with administrative privileges and install drivers and check if it helps.
Create a user account
If the issue doesn't occur then refer the following link and follow the steps to repair the corrupt user profile.
Fix a corrupted user profile
hopefully this may fix your problem.
Thanks.
Arvin
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
