Hello,
I started having a problem while trying to start a program that's been working ok since first installed several years ago. The current version been running well for months.
The problem seems to be the program application all of sudden isn't able to find vcruntime140.dll.
I'm not certain what happened i.e. if another program recently installed changed something or the problem lies elsewhere. I have uninstalled the most recently installed application. Whether it's install was or is related to the problem I'm uncertain.
The error message while trying to execute the program application.
Application has failed to start because VCRUNTIME140.dll was not found. Re-installing the application may fix this problem.
I've attempted re-installation several times plus completely uninstalling and removing all files then performing a fresh install.
Results in the same error.
I've also tried updating and replacing VCRUNTIME140.dll of which there are several versions with different dates and file sizes. when vcruntime140.dll i is installed there are two paths for 32 and 64 bit versions. Same dll file only under different paths as I'm running Windows Vista x64 so there's two paths for 32 and 64 bit applications.
C:\Windows\SysWOW64\vcruntime140.dll
C:\Windows\System32\vcruntime140.dll
I've also tried running Regsvr32
Regsvr32 C:\Windows\SysWOW64\vcruntime140.dll
Regsvr32 C:\Windows\System32\vcruntime140.dll
results with error message: Dll file was loaded but the entry-point dllregisterserver was not found
I then attempted to modify the security settings of Regsvr32.exe from these instructions, produces same error while trying to register or unregister vcruntime140.dll
____
SOLUTION OF Regsvr32: DllRegisterServer entry point was not found, Go to systemdrive(generally c
\system32 and search file "Regsvr32.exe" Right click and click in properties and go to security tab and click in advanced button. Click in owner tab and click edit and select administrators and click ok
____
I set the security with full privileges for System, Current Admin user, Administrators, Users & Trustedinstaller
With Administrators (Current Admin User) as owner.
____
\system32 and search file "Regsvr32.exe" Right click and click in properties and go to security tab and click in advanced button. Click in owner tab and click edit and select administrators and click ok____
- Thinkcentre
- Intel Core 2 CPU 2.67 Ghz
- OEM
- 4 GB
- NEC
- 1920 x 1080p
