Solved Audio Driver (Code 10) Vista
paulpepe
I have the latest version of Audio driver IDT High Definition (CODEC) installed. My problem is that it will not start. My device manager shows "this devise cannot start (Code 10)." I previously had sound and one day it was gone. I have been fighting this for months. My speakers are plugged in and powered on. I show "No audio autput devise is installed." Can anyone advise what I can do to solve this problem?
    gateway
What motherboard are you using?
Are you using onboard sound or a sound card?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Thanks for your reply. I have no idea which motherboard is installed on my Gateway x32 bit computer. I have onboard sound. .
    gateway
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
I went to the site you listed and checked to see if my computer model was listed, but it isn't. This driver appears to only apply to Notebooks since they are the only models listed. My model number is GT5408. Do I still use it?
    gateway
As it is the same audio device there is no reason why it would not work.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
Okay, here is what happens when I try to do the driver setup: I follow the wizard and the first step is it automatically updates the audio hardware configuration. When this is completed, I get the error message "exit error=Device Object not present, restart the system and run again. The same thinng happend on the second and third attempts. I am not sure what "Device Object" this message refers to. Anything else to try?
    gateway
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
I GOT SOUND!!!!! I downloaded an up to date driver and installed it and that was the problem. This amazes me because my Windows system kept telling me the old driver was current. It just wasn't starting! I really appreciate all your help and advise. Thanks loads.
    gateway
Some drivers can become damaged. Re-installing them solves the problem. Glad it is sorted.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
