Automatic System Restore
I just reinstalled from a Macrium Reflect Disk Image and everything on my box works great except that my System Restore does not work correctly. I can manually create restore points but, Vista won't make one during an update or installation of software automatically. Any ideas?
Thanks.
    Compaq Presario F730US
    AMD 64 Anthlon X2
    2GB
    Nvidia GeForce Go 6100
    1280X800
    120GB SATA
Thanks.
hi Marty,
Macrium, once installed sets priority for backups and restore. I use it as well, and as long as you set your scheduled backups in Macrium, you'll be fine. Just remember once you do your full backup again, do regular incremental backups as needed-before new software installs, registry cleans/tweaks,etc.. You can do differential backups as well if you choose.
Hope this helps.:)
    Core i7 860 Lynnfield
    Asus P7P55D Deluxe
    Corsair XMS 3 PC 1600Mhz
    ATI Radeon HD 5770
    LG 2350 Flatron HD
    1920x1080
    Barracuda 1Tb
    650w Corsair
    Antec 900
    CoolerMaster Hyper212
    5 button w/speed control
    yeah,somewhere...
    cable modem
    Running a very stable 3.6Ghz @ 8-8-8-24 1.65v
Actually, I was able to solve this problem by opening up Disk Management and setting my C partition as Active. My problem with Microsoft's System Restore is now fixed and everything works fine.
    AMD 64 Anthlon X2
    2GB
    1280X800
    120GB SATA
Glad to hear it. I assume the partition was active prior to reinstall? I use Macrium regularly, and haven't experienced that.
    Asus P7P55D Deluxe
    ATI Radeon HD 5770
    LG 2350 Flatron HD
    1920x1080
    Barracuda 1Tb
    650w Corsair
    Antec 900
    yeah,somewhere...
    cable modem
