The last 2 days I have had this problem with a Dell Inspiron 1545 laptop, and have been using it with the power adapter/charger plugged in.  Yet this morning I have started up the laptop with the power plugged in, and now it shows that the battery is plugged in & charging !!
Checking the battery yesterday it showed " battery life- moderate." As everything works fine with the power adapter plugged in, I assume that the adapter is fine.
If the problem arises again, can I use a power adapter from a Dell Inspiron 630M laptop which runs Windows 7 ? This Inspiron 1545 laptop runs Windows Vista.
Hopefully someone can advise re the use of the 630M adapter with the 1545. Will it be safe ? I do not want to cause damage to the Vista machine.
- Dell Inspiron 1545
