I really want to improve my graphics card I currently have a hd3200 and my computer is an lx6200 gateway http://www.gateway.com/systems/product/529668196.php . I have a 22 inch screen with 1680 x 1050 resolution
. I want to play Left 4 dead , in 1680 x 1050 resolution at high setting (maybe even crysis) what do you guys reccomend on the graphics card i get? I know i have to upgrade my power supply in order to do this also.
I wasnt sure if this graphics card would be able to do that http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4097752&CatId=3670
And with this graphics card i was thinking of this Psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
My budget is around 275$ give or take a few for the Psu and graphics card put together, but i was praying to spend less than 200$
So what do you guys think? 1. Do i even need to have a graphics card that high in order to get the performance i want? 2. Is the Psu compatible with my comp?
3. Is there another graphics card and psu you guys recommend at a cheaper price ( is there even a good graphics card that can do the performance i want, without having to increase my psu, i highly doubt it)?
Sorry for all my question im a little new at this
Thx for the help
. I want to play Left 4 dead , in 1680 x 1050 resolution at high setting (maybe even crysis) what do you guys reccomend on the graphics card i get? I know i have to upgrade my power supply in order to do this also. I wasnt sure if this graphics card would be able to do that http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4097752&CatId=3670
Thx for the help
