Best pci nic for Vista 64?
Recently i had a power outage at my place that apparently fried both ethernet ports on my mobo. I bought a Netgear gigabit pci adapter from circuit city(my first mistake) that "works with vista" but apparently isn't "certified"...'cause i've had nothing but problems with this thing. Most of the problems i've solved as much as i can( i can get on the internet now but Vista s3 sleep is sporadic and now i can't connect to my xbox to share media.
So i've decided to dropkick this #@$%& across the room and buy a good nic that is certified to work with Vista. Any suggestions? Thanks in advance.
- AMD Athlon 64 x2 5200+
- Asus M2N-SLI Deluxe
- 4.00 GB Kingston ValueRam
- HIS Radeon HD 4650 1GB 128-bit
- Creative Sound Blaster A-SE 7.1
- Asus 24" & Dell "19" (dual)
- 1440 x 900 & 1024 x 768
- Seagate Barracuda 320 gb Seagate FreeAgent 1tb external drive Seagate FreeAgent 500gb external drive
 - PSU
- Rosewill 750w psu
 - Case
- XCLIO Windtunnel case
 - Cooling
- ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler
- Logitech LX7 Cordless Optical Mouse
- Saitek blue lit keyboard
- over 2mbps T2
