Big Problems with Vista
Leonora
I have an Fujitsu-Siemens Amilo Laptop with a probably rotten Windows Vista x.32 OEM version as OS and I can't boot my laptop anymore. I took one of the two hard disks out of the laptop and plugged it in as an external hard disk. The disk is recognized by BIOS.
I tried to use the self repairing option which didn't help.
I tried to use the command prompt option and got a blue screen.
I tried to use the starting option in safe mode and got a blue screen.
If I try to boot with a recovery boot CD, there is a line at the bottom of the screen saying "loading files" then the message disapperars and the screen remains black. The only possibility then to shut down is to take off the power supply.
The data is saved. I just want a working OS on my laptop. Perhaps somebody has an idea what I can do.
Hello, make a bootable disk and check that hard drive using a diagnostic program : HD Diagnostic
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
It would be beneficial if you would explain exactly what happens during the boot process.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I forgot to write that I tried using an UBuntu boot disk and ended up in a shell with at least 20 error messages. :(
But thanks a lot anyway.
I forgot to write that I tried that too and ended up in a shell with at least 20 error messages. :(
What did you try ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
The information I requested would still be helpful.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I don't know yet how to reply to each of you individually.
To Yard Dog: I tried to boot from an Ubunbtu disk.
To wither3: If I switch on my laptop I can see a menu in english (I have a german version of Vista) with 3 options (the same appears when everything works normally and the battery goes low).
1.) Start windows normally
2.) Start in save mode
3.) .. command prompt
I have another idea how the problem could be solved. I could plug the hard disk (the hard disk is readable) into my laptop I use at the office and then try out the repairing from the command prompt. I wonder if this is possible even though I have Windows 7
on my office laptop?
If I understand you correctly, the data on that hard drive is saved somewhere. You should be able to reformat the hard drive from Win 7 and then reinstall Vista on the laptop using the installation disc.
There may be a bigger problem if you can't run a Linux disc. I assume that's a bootable disc that doesn't access the hard drive. Perhaps Yard Dog or you can correct me.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Data from the hard disk is saved. Unfortunately I can't reinstall VISTA because I bought my laptop with an OEM version, I don't have installation disks.
