Blue Screen problem
nastynsh
Its not even a month and am facing the blue screen of death which shows dumping physical memory.....i don't why this problem is caused ? My system config is as below :
Manufacturer - Hewlett - Pacrad
Model - HP Pavilion dv6700 Notebook PC
Processor - Intel(R) Core(TM) Duo CPU T5550 @ 1.83 Ghz
Memory (RAM) - 3070 MB
System Type - 32 - bit Operating System
Hard Disk - 250 GB
Graphic Card - Nvidia 8400 GSM
Your HP software has probably gone bad. HPs are loaded with their own software that constantly gets in the way and use tons of resorses.
I usually dump them and reinstall vista clean.
Try uninstalling any and all HP software that came with the system. Except for drivers of corse.
If that dosent work find a clean copy of Vista and start fresh.
Good luck.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
