Blue Screen problem
nastynsh
Files that help describe the problem:
C:\WINDOWS\Minidump\Mini082608-01.dmp
C:\Users\Hp\AppData\Local\Temp\WER-104099-0.sysdata.xml
C:\Users\Hp\AppData\Local\Temp\WEREB28.tmp.version.txt
These are the above notifications which are leading problem to my new laptop....i suddenly get a blue..screen saying dumping physical memory. please help me out.
My laptop Config -
3 gb ram , 1.83 ghz , 250 gb hard disk, 8400 gsm nvidia graphic card , its hp 6767tx.
The first thing to try is to go to HP's site and see if all of your drivers are up to date. Run Windows update to make sure it is all up to date.
You can also try going to your windows control panel, then go to Problem reports and solutions and if available check for new solutions
    Core Duo 2 E6700
    ASUS P5W DH Deluxe
    4g-Corsair XMS2 6400
    ATI 4870x2
    2 Maxtor Essential SATA2 drives Raid 0
    Pioneer 212D SATA DVD-R/W
The blue screen of death means your computer crashed. Did you install new hardware recently? If the drivers and solutions don't work, you can try to go to the event viewer. Just type event in the taskbar at start and open the app. Check for errors and write down the error codes and descriptions somewhere. Then go to google (or to microsoft at their online chat), type in the error codes and see what comes up and which solutions. Maybe post the error codes here too.
Amplid
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="svchost.exe" />
<EventID Qualifiers="0">0</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-08-25T19:03:26.000Z" />
<EventRecordID>18282</EventRecordID>
<Channel>Application</Channel>
<Computer>Hp-PC</Computer>
<Security />
</System>
- <EventData>
<Data>Access violation at address 004527EA in module 'svchost.exe'. Read of address 000002F4</Data>
</EventData>
</Event>
