Hi guys, I'm new to this site.
Over the past week i have started to have some pretty major computer problems, and i am certain i didn't play with any settings or download anything that could cause them, not intentionally at least. A few of the symptoms are
- Blue screen, messages vary, Irql not less or equal, memory insufficient and maybe 1 or 2 others. Blue screen occurs at random times sometimes it may happen after a few hours, and sometimes directly when it is restarting from a blue screen.
- A window pops up at various times, telling me that a program has stopped working e.g. Windows Defender
- Firefox crashes frequently, on that note so does Internet Explorer, flash player stops working if streaming something and will work for a short period of time if i reset web page.
- Sound stops working and makes a really loud stuttering sound sometimes at start-up when you hear the login tune, other times its fine for a while plays music for 30mins before it dies.
Here is the unexpected shutdown message:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 3081
Additional information about the problem:
BCCode: a
BCP1: C08027C6
BCP2: 00000000
BCP3: 00000001
BCP4: 822E2C22
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\Mini112310-04.dmp
C:\Users\Matthew\AppData\Local\Temp\WER-44226-0.sysdata.xml
C:\Users\Matthew\AppData\Local\Temp\WERBC3C.tmp.version.txt
I would really appreciate any help i can get with this, I've been to heaps of forums, run a ton of scans with AVG and PC tune-up, even tried sfc/scannow in CMD, didn't even make it to 50% before another crash.
I'll attach the minidump files on the next thread, thanks
Problem signature:
Locale ID: 3081
BCCode: a
BCP1: C08027C6
BCP2: 00000000
BCP3: 00000001
BCP4: 822E2C22
Service Pack: 2_0
Product: 768_1
- HP Compaq
- AMD Athlon 64x2 Dual Core Processor 5200+ 2.60GHz
- 3.00 GB
- NVIDIA GeForce 8400 GS
- Realtek High Definition Audio
- Sony Bravia 40" LCD TV
- 1280 by 768
- ST336032 OAS (D) Factory Image 8.67/10 GB used ST336032 (C) 195/325 GB used
