just god a new top-end audio interface and using cubase 4. I'm not sure which is causing the blue sceen. I've tried looking in the event viewer and can't see any details about the system failure. write debugging info is set to minidump.
is there some other way to check the crash info in a log? or what are the best settings for "startup and recovery". thanks
Hi Bleeping Crazy,
When you get BSOD it will display an error message, something like *x******* (where "*" represent a number) and than followed by quick description of a problem.
120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
Wireless Keyboard and mouse 3000
1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner,
15 in 1 card reader
Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
steinberg tech were asking me for a detailed crash log from windows (along with the one generated by cubase and in its respective folder)
i remember in xp i was able to save a log. as the BSOD only gives a certain amount of details.
have I got the options set right for startup & recovery?
system failure
write an event...: ticked
auto restart: off
small mem dump
%SystemRoot%\Minidump
Logitech G15 (gen 2)
Logitech MX Master (shared)
Operating System
Lenovo ThinkPad E545
AMD A6-5350M APU
Lenovo
Radeon HD (Embedded)
Conextant 20671 SmartAudio HD
Lenovo 15" Matte
1680 * 1050
If you check Event Viewer > Custom Views > Administrative Events it should show the BSOD codes, there are a few other places to get them but it should show up there and once you have them I can lookup the M$ database for the cause.
You can find the minidump file in X:\Windows\minidump folder (where "X" is your system boot drive, probably C
Check the "date created" info to make sure it's the right one that corresponds to your BSOD time.
