I just recently obtained a Asus laptop with Windows Vista Home Premium 64-bit with SP1 preloaded. Earlier I had it on, not being plugged in, and the battery went dead. Upon this I went to restart it and came to being stuck at the Boot Manager.
File:\windows\system32\winload.exe
Status:0xc0000225
Info: The selected entry could not be loaded because the application is missing or corrupt.
it tells me to insert and load the installation disc, but as it was pre-loaded, I do not have it. It also gives me the option to run Windows Memory Diagnostic, but when I select it and press Enter, it simply does nothing but goes back to the previous screan. Any help would be greatly apprecitaed. Thanks in advance.
Status:0xc0000225
well done
