BSOD- driver power state failure
mwaugh
Thanks for reading my post. I've been using my Gateway laptop for 3 years with relatively few problems. Since June or so, I've been seeing random blue screens, with no consistent series of events, or none that I can see. I'm attaching the sevensforum folder. Any help would be appreciated.
    Gateway MD7820U
    Intel Core2
    T6400 @ 2GHz
    4gb
Welcome
You reports were consistent. The cause seems to be this driver
O2sdx64.sys file descriptionProductname: O2Micro SD Reader Driver Description: O2Micro SD Reader Driver (AMD64) O2Micro
Go to the company website and update the driver or replace the software
Holy cow, that was fast! Thanks so much for checking that out. And yes, I can guarantee I was using my SD drive during the most recent crashes. I'll update the driver and hope that's the fix I need. If not, I'll just use another method to look at the pictures.
Thanks again for the quick response.
    Gateway MD7820U
    Intel Core2
    T6400 @ 2GHz
    4gb
You are very welcome and thank you for using Vista Forums.
