BSOD dump help
mikefnz
Hi all
Would really appreciate a few pointers on where best to go with a BSOD problem.
Just started happening at random and whenever I put an SD card into the (Dell) monitor.
Running Vista Business.
Ran Memtest which crashed on startup until I removed one of the two 2GB GSkill sticks of memory. Memtest said the remaining stick is fine. But putting an SD card in to test it still caused a BSOD.
I'll run a disc check next.
Haven't checked all voltages. I'll do that next....
Zipped dump file attached.
Many thanks in advance.
Mike
Update
Disc check says no problems
Voltage - BIOS says OK Vcore=1.28. DDR18V=1.88, 3.3V=3.31, 12V=12.11
PAGE_FAULT_IN_NONPAGED_AREA
STOP: 0x00000050
Usual Causes: Memory - Try without the defective stick of RAM
System Service - Try Last Known Good Configuration
Anti Virus or Corrupt NTFS volume - unlikely
It sounds very much like a bad stick of RAM. Take it out and see if this solves problem. Make sure other stick is not defective. Replace under warranty if you can.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thanks for that. After trying various combinations with Memtest, I am quite confident that the problem was one 2Gig stick.
Interesting interpretation of Gskill's "lifetime warranty" here in NZ. Apparently it means two years and I missed out by a month!
Cheers
Mike
