BSOD Help
bnhot
I'm having trouble figuring out what is going on here. I'm posting a pair of minidumps from Vista 64 SP2. If anybody can help identify the source / path to resolution, I would appreciate it.
Thanks!!!
---Brian
bnhot
the two dumps were caused by two different system files but didnt contain enough info to give detailed info
Since they were both system files I would suggest running a system file check by typing sfc /scannow in search
When it commpletes it will tell you if there were bad files and if they were fixed
good luck
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
excuse me zigzag may be this is too ridiculous to ask but when i type cmd in search and type sfc/scannow it says "You must be an administrator running a console session in order use the sfc utility" what's that? because im not an expert please tell me why is that? and im sorry if i put it here because this is only my courage to know :huh:
    Toshiba Satellite M300
    Intel core 2Duo
    2.00GB
    ATI Mobility Radeon HD 3470
    Conexant High Definition SmartAudio
    Generic PnP
    silk
    Synaptic PS/2 port touchpad
when you find cmd, right click and run as administrator. Be sure to leave a space between the "/" and scannow. C: sfc /scannow
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
jeff
Sorry I always run as admin so I forgot, and Lemur did a great save and backup. Thanks
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
alright i think im more courage than before but where is that space the right order because when in the command prompt i typed this sfc<space>/scannow<enter>
the answer is stil the same?? please tell me how you do that?:D
    Intel core 2Duo
    2.00GB
    Generic PnP
    silk
jeff
so from an elevated cmd prompt you type sfc /scannow(enter) and what happens?
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
I've try it to run as administrator and i think i find the correct typing! as lemur said thanks it might comin handy if something happen but so far i never find any problem to my vista because i often do this before everything too late :D:
1. Scan my computer for virus with avira antivir daily
2. Defragment harddrive once a week or may be often
3. Cleaning up the junk files with windows cleaner
4. Updating my antivirus
that is what i do and the most easier way to prevent crash, corruption, etc
    Intel core 2Duo
    2.00GB
    Generic PnP
    silk
