BSOD Help
Boanerges
I'm continually getting this 124 code on BSOD. This is the reason that I went back to XP, but thought that I would give Vista another try now that SP's have been realeased. Any help would be appreciated!:cry:
Specs
Mobo: Asus M2N32 SLI Deluxe Wireless
AMD 64x2 6000
EVGA 8800 GT KO
4GB Corsair DDR2 800
Problem signature
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Files that help describe the problem (some files may no longer be available)
Mini112909-02.dmp
sysdata.xml
Version.txt
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA8004428300
BCP3: 00000000B235C000
BCP4: 0000000000000175
OS Version: 6_0_6000
Service Pack: 0_0
Product: 768_1
Please browse to C:\Windows\Minidump > attach all files in that folder in .zip format here [click the small paper clip icon at the top of the text box window] > this will allow the easiest and fastest solution once that file is uploaded.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
Sorry wont let me open file to upload it. Any advice? Sorry for me being a novice. The upgrade advisor seems to be for 32 bit versions only
