BSOD help!!!
Welcome
You certainly did hav a lot of BSODs. Some indicate hardware others drivers. This is not unusual and these reports are like little clues, which finaly lead us to the true cause. Several, indicated memory and since memory can, also be the cause of a driver problem, lets start there. Im logging off after this and will answer any questions, tomorrow.
Run test for 8 passes and then take a good stick and test each slot for 8 passes.
Guide to using Memtest86+ - Geeks to Go Forums
This works out well , this is an overnight test, so you will have some reusults or questions for me tomorrow
