BSOD problem
Attached is my minidump folder. Recently I've encountered the BSOD twice and received the message of: DRIVER_IRQL_NOT_LESS_OR_EQUAL
I copied and pasted the info that Windows provided regarding the problem:
[FONT="]Additional information about the problem:[/FONT]
[FONT="] BCCode: a[/FONT]
[FONT="] BCP1: 00000000D5810010[/FONT]
[FONT="] BCP2: 000000000000000C[/FONT]
[FONT="] BCP3: 0000000000000000[/FONT]
[FONT="] BCP4: FFFFF800022C4246[/FONT]
[FONT="] OS Version: 6_0_6001[/FONT]
[FONT="] Service Pack: 1_0[/FONT]
[FONT="] Product: 768_1[/FONT]
[FONT="]Files that help describe the problem:[/FONT]
[FONT="] C:\Windows\Minidump\Mini081410-01.dmp[/FONT]
[FONT="] C:\Users\Owner\AppData\Local\Temp\WER-247745-0.sysdata.xml[/FONT]
[FONT="] C:\Users\Owner\AppData\Local\Temp\WER1B9A.tmp.version.txt[/FONT]
Your help is very much appreciated! Thanks.
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL: Usual causes: Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility
I did not do a full analysis. It appears that the cause is safecontrolfilter.sys a driver. Just uninstall the old and replace with most current and follow instructions given below.If the driver is part of your security system just uninstall and replace with security software mentiond below. If problem continues just post and you will be helped.
Safeconnectfilter.sys driver | What is Safeconnectfilter.sys file?
Sana the company that made Safeconnecfilter.sys is now part of AVG.
* Bugcheck Analysis *
Unable to load image \??\C:\Program Files (x86)\Rogers Online Protection\Rogers Online Protection\SafeConnect\Driver\platform_VISTA\SafeConnectFilter.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for SafeConnectFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for SafeConnectFilter.sys
Probably caused by : SafeConnectFilter.sys ( SafeConnectFilter+57df )
Followup: MachineOwner
Suggested Action
Replace Driver or applicable security software mentioned
Update to most current SP2
Uninstall AntiVirus and replace with Microsoft Security Essentials, Malwarebytes and Windows Firewall. AVG software should be uninstalled.
http://www.malwarebytes.org/mbam.php
http://www.microsoft.com/Security_Essentials/
Run an SFC
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
Scan with AntiVirus.
We may have to update all old drivers, but hopefully these easier steps will suffice. Safeconnectfilter is just one of the many old drivers in your system.
Thanks for the reply, richc46.
I'm a bit new to this, but should I download the safecontrolfilter.sys update in the link you gave? I don't know how to uninstall the old.
As well, when you refer to Anti-virus/AVG software, are you referring to the Rogers Online Protection software on my computer? I was going to keep that.
The company that made that safecontrolfilter.sys driver was taken over by AVG. In addition, the driver is very old, I doubt if that link is good for a download. I sent you all the infromation that I used to prepare your analysis. It would be foolish to do it twice if needed.
T
he Dump report that you gave me show several possible causes for the BSOD, my feeling is that it is the filter. We should concentrate on that.
When I refer to AVG, I refer to them only because they took over the company that made the origianal driver. At this point that is about all that I know.
To get rid of the BSOD, we need to either replace the software that uses the driver or try to replace the driver. I think replacing the driver will be difficult since it is so old and the original MFG, has become part of AVG.
I went to the Rogers Security Center download page to find the driver. I could not get in. Says its for customers only who have Rogers. May I suggest, if we are going to have problems, it would be easier to use Microsoft Security Essentials, its free and one of the Best for Windows.
I enjoy helping at the forum and will do all that I can to see that we fix your problem, but there are things that I cannot do. Read and understand this Uninstall Drivers
This is the page that stopped me. Try to get in and see if you can find the correct driver.
http://www.rogers.com/web/content/internet_security-features
Thanks richc46, I really do appreciate your help.
I actually just spoke with a Rogers Web Technician over the phone and I tried to explain the issue, but she never heard of a Blue Screen conflict with Rogers Online Protection.
However, she did direct me to the exact page you are referring to and I downloaded their latest software. I don’t know the driver specifics since it simply asked me to download their application and restart.
If this doesn’t work, I will post again.
If I did decide to uninstall the safecontrolfilter.sys driver, do you know which device it is exactly under? I am going through the Device Manager and I don’t know where to look.
Thanks again.
You should be able to find every driver by using this method.
If you cannot find i,t this is what I would do, Make a system restore point, Uninstalll the security center. There is probably an uninstall tool to do this, from the company website. Install Microsoft Security Essentials for test purposes. If you really prefer Rogers, with the restore point you can easily go back.
Lets not forget, if you look at the first post I made, it shows that the virus scanner itself may be the problem. It would have to be removed if that is the situation.
I am just trying to find short cuts for you. Officially, I am suppose to tell your replace your security. Replace all old drivers, you have plenty of those, too. I would say about 30, which includes safecontroller.
You have to send me the new DumpReport, you made changes, I do not know what is in there now. It may bsod for another reason.
I tried to locate the safecontrolfilter.sys driver under Non-Plug and Play Drivers through Device Manager, but I don’t see it.
Though, I haven’t encountered another BSOD yet so I will keep the Rogers until then.
I am interested in updating the other drivers you mentioned, but I’m not entirely sure how. Do I just manually click them all? I also noticed that I cannot find an Update option when I click on the Driver properties.
I always assumed Windows updated my drivers through Windows Update. However, I do manually pick what updates I want though; is that perhaps the issue?
Attached is my latest DumpReport. Thanks.
Before we go any further, let me just show you this. Its from the last DumpReport
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading User Symbols
Loading unloaded module list
BugCheck A, {d5810010, c, 0, fffff800022c4246}
Ill get the driver info for you soon.
Drivers in use during the last BSOD that you sent me.
Code:
 ffffa60`02b20000 fffffa60`02b2ff00   1394BUS  1394BUS.SYS  Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`008e8000 fffffa60`0093e000   acpi     acpi.sys     Fri Jul 04 01:03:08 2008 (486DAF0C)
fffffa60`042a9000 fffffa60`04316000   afd      afd.sys      Sat Jan 19 01:38:15 2008 (47919AD7)
fffff960`00870000 fffff960`008d1000   ATMFD    ATMFD.DLL    Wed May 26 10:56:53 2010 (4BFD36B5)
fffffa60`041fc000 fffffa60`041ffd00   BdaSup   BdaSup.SYS   Sat Jan 19 01:34:06 2008 (479199DE)
fffffa60`08a31000 fffffa60`08a4f000   bowser   bowser.sys   Sat Jan 19 00:54:51 2008 (479190AB)
fffff960`00650000 fffff960`00661000   cdd      cdd.dll      unavailable (00000000)
fffffa60`02a00000 fffffa60`02a1c000   cdfs     cdfs.sys     Sat Jan 19 00:53:45 2008 (47919069)
fffffa60`02b30000 fffffa60`02b4c000   cdrom    cdrom.sys    Sat Jan 19 01:29:04 2008 (479198B0)
fffffa60`0067b000 fffffa60`0072d000   CI       CI.dll       Fri Feb 22 00:20:54 2008 (47BE5BB6)
fffffa60`00793000 fffffa60`007bf000   CLASSPNP CLASSPNP.SYS Sat Jan 19 01:28:53 2008 (479198A5)
fffffa60`0061e000 fffffa60`0067b000   CLFS     CLFS.SYS     Sat Jan 19 00:53:58 2008 (47919076)
fffffa60`02c00000 fffffa60`02c0e000   crashdmp crashdmp.sys Sat Jan 19 01:28:59 2008 (479198AB)
fffffa60`011ef000 fffffa60`011f9000   crcdisk  crcdisk.sys  Sat Jan 19 01:30:12 2008 (479198F4)
fffffa60`04679000 fffffa60`04694000   DefragFS DefragFS.SYS Mon Aug 25 12:58:07 2008 (48B2E49F)
fffffa60`00bdc000 fffffa60`00bf9000   dfsc     dfsc.sys     Sat Jan 19 00:54:16 2008 (47919088)
fffffa60`00bba000 fffffa60`00bce000   disk     disk.sys     Sat Jan 19 01:29:02 2008 (479198AE)
fffffa60`02d7b000 fffffa60`02d9e000   drmk     drmk.sys     Sat Jan 19 02:20:04 2008 (4791A4A4)
fffffa60`02ddc000 fffffa60`02de6000   dump_diskdump dump_diskdump.sys Sat Jan 19 01:28:58 2008 (479198AA)
fffffa60`0460c000 fffffa60`04638000   dump_nvstor64 dump_nvstor64.sys Mon Jul 21 19:08:02 2008 (488516D2)
fffffa60`04638000 fffffa60`04644000   Dxapi    Dxapi.sys    Sat Jan 19 01:08:00 2008 (479193C0)
fffffa60`03803000 fffffa60`038e2000   dxgkrnl  dxgkrnl.sys  Fri Aug 01 21:19:59 2008 (4893B63F)
fffffa60`00dc8000 fffffa60`00df4000   ecache   ecache.sys   Sat Jan 19 01:30:39 2008 (4791990F)
fffffa60`02b55000 fffffa60`02be4580   emBDA64  emBDA64.sys  Wed Oct 03 21:13:13 2007 (47043E29)
fffffa60`037f2000 fffffa60`037ff480   emOEM64  emOEM64.sys  Wed Oct 03 21:12:45 2007 (47043E0D)
fffffa60`00acf000 fffffa60`00ae3000   fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)
fffffa60`00a89000 fffffa60`00acf000   fltmgr   fltmgr.sys   Sat Jan 19 00:54:10 2008 (47919082)
fffffa60`02dc9000 fffffa60`02dd3000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:53:41 2008 (47919065)
fffffa60`00fcf000 fffffa60`00ffb000   fwpkclnt fwpkclnt.sys Sat Jan 19 01:36:43 2008 (47919A7B)
fffffa60`02b4c000 fffffa60`02b55000   GEARAspiWDM GEARAspiWDM.sys Tue Apr 08 15:15:59 2008 (47FBC46F)
fffff800`02201000 fffff800`02247000   hal      hal.dll      Sat Jan 19 02:55:25 2008 (4791ACED)
fffffa60`02afb000 fffffa60`02b0e000   HDAudBus HDAudBus.sys Tue Nov 27 18:24:06 2007 (474CA716)
fffffa60`02de6000 fffffa60`02dedb80   HIDPARSE HIDPARSE.SYS Sat Jan 19 01:33:51 2008 (479199CF)
fffffa60`0475a000 fffffa60`047f9000   HTTP     HTTP.sys     Sat Feb 20 16:40:34 2010 (4B8056D2)
fffffa60`02a55000 fffffa60`02a6b000   i8042prt i8042prt.sys Sat Jan 19 01:28:08 2008 (47919878)
fffffa60`02a74000 fffffa60`02a82000   kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`00600000 fffffa60`0060a000   kdcom    kdcom.dll    Sat Jan 19 02:58:25 2008 (4791ADA1)
fffffa60`02d9e000 fffffa60`02dc9000   klif     klif.sys     Mon Jan 19 11:09:02 2009 (4974A59E)
fffffa60`03748000 fffffa60`0377c000   ks       ks.sys       Sat Jan 19 01:28:24 2008 (47919888)
fffffa60`00ae3000 fffffa60`00b6a000   ksecdd   ksecdd.sys   Mon Jun 15 09:27:03 2009 (4A364C27)
fffffa60`041e4000 fffffa60`041e9180   ksthunk  ksthunk.sys  Sat Jan 19 01:28:14 2008 (4791987E)
fffffa60`0472e000 fffffa60`04742000   lltdio   lltdio.sys   Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`04657000 fffffa60`04679000   luafv    luafv.sys    Sat Jan 19 00:59:06 2008 (479191AA)
fffffa60`04644000 fffffa60`04657000   monitor  monitor.sys  Sat Jan 19 01:32:34 2008 (47919982)
fffffa60`02a82000 fffffa60`02a8e000   mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`009d6000 fffffa60`009e9000   mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)
fffffa60`08a4f000 fffffa60`08a69000   mpsdrv   mpsdrv.sys   Sat Jan 19 01:35:28 2008 (47919A30)
fffffa60`08a69000 fffffa60`08a90000   mrxdav   mrxdav.sys   Sat Jan 19 00:55:28 2008 (479190D0)
fffffa60`08a90000 fffffa60`08ab9000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:46:43 2010 (4B83C023)
fffffa60`08ab9000 fffffa60`08b02000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:46:40 2010 (4B83C020)
fffffa60`08b02000 fffffa60`08b21000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:46:37 2010 (4B83C01D)
fffffa60`04237000 fffffa60`04242000   Msfs     Msfs.SYS     Sat Jan 19 00:53:55 2008 (47919073)
fffffa60`00947000 fffffa60`00951000   msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)
fffffa60`038fa000 fffffa60`03932000   msiscsi  msiscsi.sys  Sat Jan 19 01:30:31 2008 (47919907)
fffffa60`08151000 fffffa60`08152a00   MSPQM    MSPQM.sys    Thu Nov 02 05:37:30 2006 (4549BC5A)
fffffa60`00b6a000 fffffa60`00bba000   msrpc    msrpc.sys    Sat Jan 19 01:27:01 2008 (47919835)
fffffa60`0377c000 fffffa60`03787000   mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)
fffffa60`011dd000 fffffa60`011ef000   mup      mup.sys      Sat Jan 19 00:54:18 2008 (4791908A)
fffffa60`00c05000 fffffa60`00dc8000   ndis     ndis.sys     Sat Jan 19 01:37:13 2008 (47919A99)
fffffa60`03962000 fffffa60`0396e000   ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)
fffffa60`0396e000 fffffa60`0399f000   ndiswan  ndiswan.sys  Sat Jan 19 01:37:33 2008 (47919AAD)
fffffa60`037de000 fffffa60`037f2000   NDProxy  NDProxy.SYS  Sat Jan 19 01:37:26 2008 (47919AA6)
fffffa60`04378000 fffffa60`04387000   netbios  netbios.sys  Sat Jan 19 01:36:35 2008 (47919A73)
fffffa60`04316000 fffffa60`0435a000   netbt    netbt.sys    Sat Jan 19 01:36:24 2008 (47919A68)
fffffa60`00e03000 fffffa60`00e5b000   NETIO    NETIO.SYS    Sat Jan 19 01:37:27 2008 (47919AA7)
fffffa60`04242000 fffffa60`04253000   Npfs     Npfs.SYS     Sat Jan 19 00:53:57 2008 (47919075)
fffffa60`043f0000 fffffa60`043fc000   nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)
fffff800`02247000 fffff800`0275f000   nt       ntkrnlmp.exe Thu Feb 18 06:38:33 2010 (4B7D26B9)
fffffa60`0100d000 fffffa60`01191000   Ntfs     Ntfs.sys     Sat Jan 19 00:55:29 2008 (479190D1)
fffffa60`02dd3000 fffffa60`02ddc000   Null     Null.SYS     Thu Nov 02 05:37:15 2006 (4549BC4B)
fffffa60`02e00000 fffffa60`03724380   nvlddmkm nvlddmkm.sys Sun Oct 12 14:35:58 2008 (48F2438E)
fffffa60`02c0e000 fffffa60`02d7a180   nvmfdx64 nvmfdx64.sys Fri Aug 01 14:38:28 2008 (48935824)
fffffa60`007bf000 fffffa60`007e2000   nvraid   nvraid.sys   Wed Jun 06 16:34:01 2007 (46671A39)
fffffa60`009aa000 fffffa60`009d6000   nvrd64   nvrd64.sys   Mon Jul 21 19:07:58 2008 (488516CE)
fffffa60`02a8e000 fffffa60`02a99000   nvsmu    nvsmu.sys    Thu May 22 12:39:26 2008 (4835A1BE)
fffffa60`00a00000 fffffa60`00a2c000   nvstor64 nvstor64.sys Mon Jul 21 19:08:02 2008 (488516D2)
fffffa60`02b0e000 fffffa60`02b1fa00   ohci1394 ohci1394.sys Sat Jan 19 01:34:08 2008 (479199E0)
fffffa60`0435a000 fffffa60`04378000   pacer    pacer.sys    Fri Apr 04 21:55:46 2008 (47F6DC22)
fffffa60`00981000 fffffa60`00996000   partmgr  partmgr.sys  Sat Jan 19 01:29:14 2008 (479198BA)
fffffa60`00951000 fffffa60`00981000   pci      pci.sys      Sat Jan 19 01:02:57 2008 (47919291)
fffffa60`08000000 fffffa60`080b6000   peauth   peauth.sys   Mon Oct 23 07:57:00 2006 (453CAE0C)
fffffa60`041a9000 fffffa60`041e4000   portcls  portcls.sys  Sat Jan 19 01:33:58 2008 (479199D6)
fffffa60`02a42000 fffffa60`02a55000   processr processr.sys Sat Jan 19 00:52:45 2008 (4791902D)
fffffa60`02a6b000 fffffa60`02a74000   PS2      PS2.sys      Thu Sep 07 18:49:03 2006 (4500A1DF)
fffffa60`0060a000 fffffa60`0061e000   PSHED    PSHED.dll    Sat Jan 19 02:58:13 2008 (4791AD95)
fffffa60`02be5000 fffffa60`02bf8000   RapportKE64 RapportKE64.sys Thu Jul 01 05:05:24 2010 (4C2C5A54)
fffffa60`041ea000 fffffa60`041fc000   RapportPG64 RapportPG64.sys Thu Jul 01 05:05:34 2010 (4C2C5A5E)
fffffa60`04253000 fffffa60`0425c000   rasacd   rasacd.sys   Sat Jan 19 01:37:30 2008 (47919AAA)
fffffa60`0393f000 fffffa60`03962000   rasl2tp  rasl2tp.sys  Sat Jan 19 01:37:33 2008 (47919AAD)
fffffa60`0399f000 fffffa60`039af000   raspppoe raspppoe.sys Sat Jan 19 01:37:30 2008 (47919AAA)
fffffa60`039af000 fffffa60`039cd000   raspptp  raspptp.sys  Sat Jan 19 01:37:34 2008 (47919AAE)
fffffa60`039cd000 fffffa60`039e5000   rassstp  rassstp.sys  Sat Jan 19 01:37:42 2008 (47919AB6)
fffffa60`043a2000 fffffa60`043f0000   rdbss    rdbss.sys    Sat Jan 19 00:55:09 2008 (479190BD)
fffffa60`04225000 fffffa60`0422e000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`0422e000 fffffa60`04237000   rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)
fffffa60`03737000 fffffa60`03748000   rp_pkt64 rp_pkt64.sys Thu Apr 05 14:51:01 2007 (46154515)
fffffa60`039e5000 fffffa60`039fa000   rp_skt64 rp_skt64.sys Wed Nov 26 15:15:20 2008 (492DAE58)
fffffa60`04742000 fffffa60`0475a000   rspndr   rspndr.sys   Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`04009000 fffffa60`041a8b80   RTKVHD64 RTKVHD64.sys Wed Feb 11 07:39:19 2009 (4992C6F7)
fffffa60`080dc000 fffffa60`0811b000   SafeConnectDriver SafeConnectDriver.sys Sat Dec 15 23:30:41 2007 (4764A9F1)
fffffa60`080b6000 fffffa60`080c2000   SafeConnectFilter SafeConnectFilter.sys Sat Dec 15 23:30:28 2007 (4764A9E4)
fffffa60`080c2000 fffffa60`080cd000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffffa60`0428e000 fffffa60`042a9000   smb      smb.sys      Sat Jan 19 01:36:17 2008 (47919A61)
fffffa60`011d5000 fffffa60`011dd000   spldr    spldr.sys    Thu Jun 21 20:57:56 2007 (467B1E94)
fffffa60`04694000 fffffa60`0472e000   spsys    spsys.sys    Thu Jun 21 21:02:05 2007 (467B1F8D)
fffffa60`08b53000 fffffa60`08bea000   srv      srv.sys      Fri Dec 11 07:26:54 2009 (4B223A8E)
fffffa60`08b21000 fffffa60`08b53000   srv2     srv2.sys     Mon Sep 14 06:00:18 2009 (4AAE1432)
fffffa60`08a09000 fffffa60`08a31000   srvnet   srvnet.sys   Fri Dec 11 07:26:38 2009 (4B223A7E)
fffffa60`00a2c000 fffffa60`00a89000   storport storport.sys Sat Jan 19 01:29:09 2008 (479198B5)
fffffa60`039fa000 fffffa60`039fb480   swenum   swenum.sys   Thu Nov 02 05:37:33 2006 (4549BC5D)
fffffa60`00e5b000 fffffa60`00fcf000   tcpip    tcpip.sys    Thu Feb 18 07:16:37 2010 (4B7D2FA5)
fffffa60`080cd000 fffffa60`080dc000   tcpipreg tcpipreg.sys Sat Jan 19 01:37:01 2008 (47919A8D)
fffffa60`03932000 fffffa60`0393f000   TDI      TDI.SYS      Sat Jan 19 01:38:11 2008 (47919AD3)
fffffa60`0425c000 fffffa60`04279000   tdx      tdx.sys      Sat Jan 19 01:36:53 2008 (47919A85)
fffffa60`03725000 fffffa60`03737000   termdd   termdd.sys   Sat Jan 19 01:42:03 2008 (47919BBB)
fffff960`00490000 fffff960`0049a000   TSDDD    TSDDD.dll    Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`02a39000 fffffa60`02a42000   tunmp    tunmp.sys    Sat Jan 19 01:36:30 2008 (47919A6E)
fffffa60`03787000 fffffa60`03797000   umbus    umbus.sys    Sat Jan 19 01:34:16 2008 (479199E8)
fffffa60`04000000 fffffa60`04001e00   USBD     USBD.SYS     Sat Jan 19 01:33:53 2008 (479199D1)
fffffa60`02aea000 fffffa60`02afb000   usbehci  usbehci.sys  Sat Jan 19 01:33:57 2008 (479199D5)
fffffa60`03797000 fffffa60`037de000   usbhub   usbhub.sys   Sat Jan 19 01:34:13 2008 (479199E5)
fffffa60`02a99000 fffffa60`02aa4000   usbohci  usbohci.sys  Sat Jan 19 01:33:56 2008 (479199D4)
fffffa60`02aa4000 fffffa60`02aea000   USBPORT  USBPORT.SYS  Sat Jan 19 01:34:00 2008 (479199D8)
fffffa60`04279000 fffffa60`0428e000   USBSTOR  USBSTOR.SYS  Sat Jan 19 01:33:58 2008 (479199D6)
fffffa60`02dee000 fffffa60`02dfc000   vga      vga.sys      Sat Jan 19 01:32:21 2008 (47919975)
fffffa60`04200000 fffffa60`04225000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)
fffffa60`00996000 fffffa60`009aa000   volmgr   volmgr.sys   Sat Jan 19 01:29:12 2008 (479198B8)
fffffa60`0072d000 fffffa60`00793000   volmgrx  volmgrx.sys  Sat Jan 19 01:29:45 2008 (479198D9)
fffffa60`01191000 fffffa60`011d5000   volsnap  volsnap.sys  Sat Jan 19 01:29:47 2008 (479198DB)
fffffa60`04387000 fffffa60`043a2000   wanarp   wanarp.sys   Sat Jan 19 01:37:35 2008 (47919AAF)
fffffa60`038e2000 fffffa60`038f1000   watchdog watchdog.sys Sat Jan 19 01:07:23 2008 (4791939B)
fffffa60`00800000 fffffa60`008da000   Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)
fffffa60`008da000 fffffa60`008e8000   WDFLDR   WDFLDR.SYS   Sat Jan 19 01:32:33 2008 (47919981)
fffff960`000d0000 fffff960`00383000   win32k   win32k.sys   Sat May 01 10:25:48 2010 (4BDC39EC)
fffffa60`038f1000 fffffa60`038fa000   wmiacpi  wmiacpi.sys  Sat Jan 19 01:02:42 2008 (47919282)
fffffa60`0093e000 fffffa60`00947000   WMILIB   WMILIB.SYS   Sat Jan 19 01:33:45 2008 (479199C9)
fffffa60`0813b000 fffffa60`08151000   WUDFPf   WUDFPf.sys   Sat Jan 19 01:33:22 2008 (479199B2)
fffffa60`0811b000 fffffa60`0813b000   WUDFRd   WUDFRd.sys   Sat Jan 19 01:33:43 2008 (479199C7)
Anything prior to July 09 is considered old
Put the name of the driver in search. If something comes up and it is not MSoft. Then it should be replaced, if you recognize the source as one of your programs. We do not want to change things we are not sure of.
http://www.runscanner.net/filelist.aspx?l=a
I put your problem driver in and got this
http://www.runscanner.net/file/fltmgr.sys.html
So that means that the safecontrolfilter.sys driver is still an issue. I tried searching the Rogers Online folder and I still can’t find it though. I guess I will uninstall Rogers then.
I apologize for these questions, but I’m not sure what I should be doing next:
1) There seems to be a lot of outdated drivers, is there a method of updating all?
2) Most of the drivers seem to be Microsoft-related, therefore should I not bother replacing them?
3) I don’t know where these drivers are located through Device Manager. For example, I noticed that the driver eremOEM64.sys is non-Microsoft. I can't find it under Device Manager and if I were to update, do you suggest I go to the eMPIA Technology website to update it?
4) If the fltmgr.sys driver is a major issue, according to the link, the solution is to run a registry scan. Do I continue?
Thanks for your help.
Just make a system restore point, before the uninstall the security, you can go back with no problem if you so desire.
No drivers are done one at a time.
You should always try to go to the website for the best and most up to date. If done automaticllay, many times you get a driver "one size fits all" and not the best.
You do not have the expertise to get involved with the registry, do not do that. I do not think that it is even necessary.
When I get a chance, I will pick one driver and we will up date toghether, so you can see how it is done.
Step one to install
Do you you know how to get this information on this driver. This is an old one that will cause problems now or in the near future.
http://www.runscanner.net/file/emBDA64.sys.html
If you get this far we go to step 2
Step 2: With Google you find out the webpage of the manufacturer and look for downloads.
Please type with a bit bigger font.
EM28xx with UAC has 3 choices to choose from. On this side of my computer I have no way of knowing which is correct. If you are confident, make a System Restore Point, save to the desktop, uninstall and then install.
You are suppose to uninstall first. I gave you a tutorial on how to find the hidden drivers, use that, you will find it.
Why not start with one that you can find, just show me first. After a little practice you will get better.
Yes that's what I have been doing, I've tried both methods for showing Hidden Devices and I still don't see a driver called Embda64.sys.
I looked under Non-Plug & Play Drivers and the only drivers that begin with the letter E are EraserUtilDrv. I've gone through all the Devices and I don't see anything named
Embda, EM26, BDA, or the company's name eMPIA or Egalax. Unless it is titled under another name.
Sorry for the frustrations.
Forget that one. Uninstall one that you can find. Do that a few times. Once you get comfotable in device manager, you will do better.
