C Drive Issues
Feruk
Hi, can someone tell me what's wrong with my computer? My C drive is filling up for some reason. I haven't installed anything new to it in a long time and have next to nothing downloaded on it. The drive is 70GB of which about 17 GB is stuff I've added. However, I apparently have used up 68 GB!! ANtivirus (AVG, Norton previous) hasn't detected anything.
It appears my C:\Windows is 19 GB and another file, C:\Users\Myname is using up another 16 GB. Can I reduce these, and how? Also, that leaves another 26GB completely unaccounted for! What's going on here? Help please.
Welcome
Without more information, I would assume that it is system restore points. They will continue to fill up the space allocated, until full. At that point they be deleted one by one as you add new points.
Since you did not fill out your system specs, if you have professional or enterprise editions, the space is most likely from shadow copies.
Used Shadow Copy Storage Space: 5.15GB
Allocated...: 5.41GB
Maximum...: 5.9GB
This doesn't account for the amount of hard drive space I'm missing. System specs:
Acer Aspire 5920G
Intel Core 2 Duo CPU T5250 @1.5GHz, 2GB Ram, 32-bit OS
Windows Vista Home Premium
You're hard drive is probably filling up because of System restore point and maybe Page File. I would check that.
To check page file...
http://www.vistax64.com/tutorials/132201-virtual-memory-paging-file-change.html
Right Click on My Computer->Properties->Click "Perfomance" at bottom left of the Window->Adjust Visual Affects>New windows should pop up, on it, click Advanced-> and Under Virtual Memory, click change.
I would make page file the same space as your RAM. Here's mine...
Also, are you sure you didn't download a large game or something?
Good luck to you.
    AMD
    ATI
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
