I can save and connect to the unpassworded connection. But I can't to the passworded one. It said access denied.
Windows Vista Home Basic 32bit
I'm searching and using these 3rd party software after I got this WiFi problems so that I could get connected.You are using a lot of third party applications which I am not familiar with and do not know what exactly they do and could very well be the cause of this mess.
I can connect to the internet if I set the router wifi settings to be without password(No authentication). When I set the router wifi settings again to the authenticated settings such as WEP, WPA, WPA2, I cannot connect to it using this Vista but I can with other PC.If you can connect to the internet without a passphrase then to my knowledge the router you are connecting to does not need authentication therefore you should not be able to enter a password and upon doing so the router should reject it.
I can connect to the internet using other PC with or without password regarding the wifi settings of the router.It may well be the routers fault since certain wireless settings (In particular channels and authentication methods) can have different affects.
The Windows kept restarting during the boot of Safe Mode with Networking.
It stopped a few seconds at crcdisk.sys(something like that) and the computer restarted itself.
A bigger bizarre is happening.![]()
That's not good. Try the steps in this post: Unable to boot - Safe Mode stops after crcdisk.sys - Microsoft Community
