card reader
I believe I have a driver problem. The problem being that the driver thinks it works but it doesn't. My card reader on my advent 5401 does not work. I know it's a software problem because when I run my system under linux it works fine. The driver I have installed is Texas Instruments PCIxx12 2.006. (I have already uninstalled and updated it.) I don't use my card reader often but I kind of would still like it to work.
    advent
Go to device manager and look for any yellow markers by the driver, if none, try to roll back to previous version. New is not always best
Try to roll back to earlier driver.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Have you tried uninstalling and reinstalling?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
racingsnail, Hello .
I have followed this thread and it appears as if you may have a file that has wrong value while using windows OS , but, it works using Linux, which to me indicates that somehow the windows file that controls this needs repairing.
I recently showed some files not repaired using Scannow , which is a command prompt that goes like this :
sfc /scannow .
Give this a read and see if it helps you out. Oh, my files not repaired dealt with the sidebar , seems as if Microsoft is aware of it and advises not to be concerned, so, that is a relief for me. Here is what i used to repair my files, which did not require a clean install or a dvd to pull applicable files off of , or a need to use a dvd for a repair program.
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
Post back if this was of any use, if not, keep it handy for other uses, if ever needed . Good luck !!
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
If you try in another user account it may work. If you do not have one create one, at least for a test.
