CD/DVD Drive Not Detected
So I tried playing a game and my computer says that the CD/DVD drive is not detected at all. I've tried fixing the registry, and some other things but nothing seems to be working. Please Help!!!
Welcome
Go to search and type device manager. In device manager, make sure there are no yellow markers, indicating driver problems. Go specifically to dvd/cd drives and other drives and make sure they are up to date.
Try this
press Windows key and R
Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Exit Registry Editor.
Restart the computer.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Well I decided to just take it too Rockstar Computers after hours of trying to figure this out. After a while of going through all the steps and even replacing the disk drive with another and it still not working, he determined it is the actual board for the disk drive that died. He said that this is a very common thing to go out on HP's since they don't actually make their own drivers. Thanks for all the help guys!
