Hey guys,
My PC is currently partitioned, my OS is installed on a 30gb partition to just host the OS, and the rest of my disk is the D partition. Unfortunately I do not know of a way to make Vista think that my "My Documents" folder / area would be on a different disk, so I manually made my own and use it on the other partition.
One of the things I find super annoying is whenever I go to open a file, for example try to attach something to an email, it by default goes to the My Documents area on the C Drive. Is there a way to change the path that it goes to first when opening / attaching files like that?
Thanks!
Thanks!
