Solved choosing a cable modem?
msongs
Msongs
hello we are getting cable internet (charter) and need to get our own modem. suggestions on brands n models? not doing anything fancy just internet. we are getting 5mbps service, wanted 10 mbps but they whack us with a jack up charge for not getting a package with tv. we dont watch tv, only want internet....grrrr.
so modem choice?
btw they run they wire n we just plug their cable in one side and another into the computer? thanks!
    built my own
    Intel i7 920 w/intel heat sink/fan
    gigabyte EX58-DS4
    3 x 2gb Corsair DDR3
    geforce 9400gt
    onboard HD
    Samsung 215TW
    1680 x 1050
    WD caviar black 640gb
    Enermax 650w
    antec p182
    3 case fans + cpu fan
    generic usb
    generic ps/2
    100 mbps
msongs
Any major mfr. I happen to like linksys motorola, dlink. I prefer linksys because its more stabile.
You only have 1 computer? the modem is all you need, if more maybe router. You wired or wifi?
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Linksys ot Netgear would be my choices.
    Dell
    Q6600
    HP w2207h
Hello Msongs,
The Motorola SB5101 is a good one, and not expensive at all.
I believe the cable companies are moving to the DOCSIS 3.0 standard. So I would make sure the modem supports this. I am looking at the Motorola SB6120 to replace my Motorola SB4101.
    AMD Athlon 64 x2 6000+
    abit KN9 sli
    2GB
    GeForce 7300GT
    Realtek HD
    Samsung 22" LCD widescreen
    native
    WD 320GB x 3 - one of these is Win 7 Maxtor 200GB - WinXP
    550W
    Antec
    2 x 120mm
    MS wireless
    MS wireless
    8MB
Hi TFW,
I just switched to the SB6120 as well.
Be sure that it has the latest firmware though for it to work perfectly. Mine didn't and I'm having to RMA it back to Motorola to get a replacement with the latest firmware. The firmware cannot be upgraded by us end-users. Some ISPs may be able to push a firmware upgrade to your modem if they support this model of modem though. You'll have to check their supported modem list to see if they do.
The older SB6120-1.0.1.1-SCM02-NOSH version has known issues of randomly losing network connections, and having to restart the modem to fix it.
I have used Motorola modems without fail. Reliable.
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
I agree. The moto surfboards are great devices. +1 for the moto
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
thanks the replies, here's what we are going to do....
signed up for cable internet today, and we will let them provide the modem. They are only charging $2/month for it and then they will be responsible for it working or not, not us. thanks for your suggestions as always.
on the other issue of gouging us for and extra $10/month because we are not getting their bundle, its just costing them because a) we decided to get 5mb instead of 10mb since they took the $10 difference out of our pockets already, and b) if we do want tv or other services we will not get it from charter since we are paying them $10/month for nothing. oh well.
thanks again :-)
    built my own
    gigabyte EX58-DS4
    geforce 9400gt
    onboard HD
    Samsung 215TW
    1680 x 1050
    Enermax 650w
    antec p182
    generic usb
    generic ps/2
    100 mbps
