Solved Column width
musicis
Wondering if the width of a particular column (Name, type, total size, etc) can be permantly adjusted. I am tired of dragging the Details or Name column to more width so to see all information. It always opens a window in default at about 1 1/2 inches wide. Never wide enough to see all. Can anything be done to adjust all this? Thanks in advance. Regards Rick :)
File>edit>view>choose detail>set column # to what you want.
Hope this helps
Ken
EDIT:
Brink
Great minds do think alike you are just way faster and know exactly where the tutorial is
thanks
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
LOL. ;)
Hope this helps
Ken
EDIT:
Brink
thanks
This method will not save the changes. I do very much appreciate all the feedback answers. The "the size all columns to fit" Worked. Needs to be done on each window type. "My Computer", "My Pictures", "My music" etc
Musicis,
I'm happy to hear that you got it sorted. :)
