Solved Complete system restore question. Will it delete other backups?
I am about to do a Complete PC Restore but I'm afraid that doing so would delete the other backed up files I have on the sam drive the Complete PC Restore image is on. Will doing this delete the backed up files?
Hello Spazplayer,
As long as the drive/partition that you are restoring the image to does not have the other backups on it and on a separate drive, then you will be fine.
Thanks fro replying,
I have the Windows complete restore image and the files I daily back up on an external USB hard drive. I am restoring my computer using the image and then I want to be able to use the backed up files to bring my system back to the day before my problem occurred. Will I be able to do this or will everything on the external hard drive be deleted? The restore image is from a month or so ago, my backed up files are more recent.
Everything on the external drive will be safe since you are restoring to another drive on the computer. :)
You're most welcome. I don't blame you. :)
