Computer running slow
samdog
Hi can someone please give me a little advice please,
I am running Windows Vista 32 bit edition and the last weeks my computer has slowed down to a snail’s pace, i have checked for viruses and it is clean. I have run CCleaner and to remove all the rubbish but it is still very slow.
I even have trouble booting from a Vista boot DVD, it take approx 5 minutes just to get the welcome screen up that’s before any OS has booted.
I have a CPU monitor on the sidebar and the CPU and the Memory usage is up and down from nothing to 100 % all the time.
And when i do get the computer to work it is very slow and i can only open one window at a time
Anybody got any ideas please
    Custom Made
    Intel Core 2 Duo
    Asus P5B Deluxe
    2Gig
    Nvidia Geforce 8600GT
    On Board
In a cmd prompt, from an administrator account type sfc /scannow. It may correct any corruption
you should download a program to hitmanpro. it's very useful and helped me a lot, you'd be surprised to see how much junk and possible harmful things to your computer there are in your computer!
    Compaq Presario
    AMD Phenom-64 8750 (2.4GHz)
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Is your memory reaching 100 percent. If it is then you are then your pagefile isnt large enought, or it isnt reading all of the memory correctly.
Does your System Properties say that you are at 2GB?
    HP Pavilion DV7-1129wm Entertainment PC
    AMD Turion X2 RM-72 Dual Core @ 2.1GHz
    2 x 2 GB Hyundai DDR2 400 MHZ
    ATI Mobility Radeon HD 3200 @ 256 MB
    IDT High Definition Audio/SRS Premium Sound/Altec Lansing
    17" Laptop Screen
    1440 x 900 laptop, external 17 in LCD 1024 x 768
    WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
    8 Cell Lithium Ion Battery
    Laptop with "light up" HP Logo on outside
    Insane air coming out of Targus dual fan cooler
    Microsoft Wireless Mobile Mouse 3000 / Touchpad
    Full Keyboard with numpad
    Comcast Cable 20 MBps
    Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
where did you get it from? I just tried 4 or 5 sites and there all broken!! :confused:
    acer aspire 6930
    3GB
    onboard
    onboard
    320GB
below someone has posted the website, it's perfect for me, however, some lame virus now has made it stop working everytime i get to 6000 files scanned LOL
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Why are you trying these programs? They never fix the problems...especially if it modifies registry entries. You are better off diagnosing the problem correctly. You never answered if you were running at 100 percent of system memory or not. What anti-viruses do you have installed? They could be causing system resources to be wasted if running constantly. Microsoft Security Essentials will make you computer run fine if you use that.
    17" Laptop Screen
How do you run this as an admin? It saying I need to run as admin. Thanks.
    Dell XPS400
    Intel Pentium D CPU 2.80 GHz
    NVIDIA GeForce 8500 GT
    2 @ 250 GB
    Logitech Wave
right click it and choose "run as administrator" (command prompt)
good luck...
    acer aspire 6930
    3GB
    onboard
    onboard
    320GB
Thank You
    Dell XPS400
    2 @ 250 GB
    Logitech Wave
Optimize the system services by creating a profile with minimal no of services. Services are nothing but the background processes. There are some services which are not necessary. Such services should be stopped.
1. Press Windows Key + R.
2. Type "services.msc" in the Open textbox.
3. Click the OK button.
4. Right click a service you would like to terminate, and select Properties option.
5. Service Properties dialog will open.
6. Click the Stop button.
7. Select "Manual" from the "Startup Type" drop down box.
8. Click the OK button.
9. Do the same for all unnecessary services.
Use the Zombie Soft Fix. Select "computer runs slow" in the drop down box. Select the operating system from the subsequent drop down box. Follow the wizard.
Windows provides a way to optimize system settings for best performance. You can either customize Windows for best performance or best appearance. The former option should be selected as shown below:
1. Right click Computer desktop icon.
2. Select Properties.
3. Click "Advanced system settings" link.
4. Click the Advanced tab.
5. Click Settings under Performance frame.
6. Click the Visual Effects tab.
7. Select "Adjust for best performance" option.
8. Click OK | OK.
9. Restart your computer for the changes to take effects. :sleepy::cry:
