Computer Running Slow
Vintage Fee
For the last few weeks my laptop has been running very slowly. When I try and open any shortcut it can take between 5 and 10 seconds to open up. Firefox regularly freezes - it switches to 'not responding' every few minutes and I have to sit and wait for it to start working again. This only takes a few seconds, but as you can imagine it's very annoying having to do this so regularly!
I know absolutely nothing about computers so had my boyfriend take a look. He ran a cache cleaner (which I do at least once a week anyway), a registry optimizer and a defrag - though it told him the computer didn't need one at the moment and was up to date. My virus software (AVG) is up to date too - when it first started running slowly I ran a few scans just to double check I hadn't accidentally acquired some sort of virus.
He's gone through and deleted programmes I don't use. I also had a lot of things activated to start up with the laptop, so he cancelled some of those to see if it'd increase the performance. We can't figure out what else it could be, so he suggested I post my problem on here in the hope that somewhere out there can help us out!
Cheers in advance!
    Compaq Pressario CQ60
    GenuineIntel(R) CPU T1600 @ 1.66GHz 1.66 GHz
    3.00 GB
In addition to my above post, if none of the attempts are successful, here is a list of the most common reasons for a slow computer
10 Reasons Why Your Computer Runs Slow -
Maintain the computer properly
To maintain your computer
10 Tips on How to Properly Maintain Your Computer
Steps that I did not notice on the guide include:
Running a scan disc before doing a defrag
Using Microsoft Security Essentials and Malwarebytes.
Making System Restore points, at least once a week
Makaing a system Image once a month (varies by user)
Not relying on your A/V common sense, should prevail. You know of many sites can cause a problem.
Do not use any reg cleaning or optimizing software.
Download and use Ccleaner about once every two months. Untick any registry entries.
http://www.piriform.com/
If you follow these instructions, you will be trouble free for a long time to come.
Be sure to back up your hard drive about once a month (varies by user) and to keeep system restore points up to date.
Optimize Windows 7
There are many Ways to Speeding up Vista alot of them are mentioned in this Tutorial
http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html
Also if you find any MS Services that you do not use For Example (VPN or Connection to Company Networks) Then you may Disable them
Disabling the Wrong Services may make you computer Inoperable. Vista Forums or Microsoft is not Responisble for any Damage made to your computer. Please proceed at your own Risk
Depending on your Hardware the Speed that is Avaliable to your Computer is Different to Mine
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Brilliant, thanks a lot guys. Will give those suggestions a try in the next few hours and see if it helps me out!!
    3.00 GB
With the two tutorials and the other suggestions that we gave , you will find your solution.
you can run a memory checker as well that will check the integrity of the system RAM to ensure its working correctly
some BIOS's come with this feature built in, this can be accessed by pressing usually an 'F' key or Esc during initial booting of the machine, and digging around in the bios menus to find it.
check you pc has also recognised all the ram installed as i recently had a very slow runnin laptop and turned out one of the physical memory modules had failed, effectively leaving me with half the memory!
more info the computer would help, make/model etc
hope you sort it!
    Fujitsu Siemens
    Intel Core 2 Due T7250 2.0GHz
    Amilo xi2528
    2Gb DDR2
    nVidia GeForce 8600M GS
    17" TFT
hope you sort it!
:confused: Huh
    AMD HD Radeon 6870
    Novatech Night
certain BIOS programs on certain motherboards have a RAM checker in them, you can run that to test the memory
    Fujitsu Siemens
    Amilo xi2528
    2Gb DDR2
    17" TFT
I have never known a Motherboard to have a RAM Checker in them - I have heard of RAM Remapping but that is not on a Laptop Mobo
To Check your memory Please see the Attached Folder
RAM Checker will not Speed up your computer but will Check it for any Faulty RAM Sticks
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
