Computer will not start
jskitt2
Vista Home Premium in my Dell XPS M1730 won't start. When I was working that night, all the programs were automatically closed without saving, and the system shut down for no reasons. I had to start it, but it won't start. Both Safe Mode and Safe Mode with Networking won't start either. Startup Repair was unable to fix the problems. I went F8 and had my computer into full diagnostic analysis on hardware, and there was no problem found in the hardware. Still, Vista won't start.
So then I tried the safe mode option, pressing F8 on startup. In starting in Safe Mode, it stops every time on one named "windows\system32\drivers\crcdisk.sys."
I ran into Command Prompt and showed the result below. Please see bold.
Any suggestions? Your assistance would be greatly appreciated.
C:\>chkdsk
The type of the file system is NTFS.
The volume is in use by another process. Chkdsk might report errors when no corruption is present.
Volume label is OS.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files <stage 1 of 3>
255616 file records processed.
File verification completed.
819 large file records processed.
0 bad file records processed.
0 EA records processed.
43 reparse records processed.
CHKDSK is verifying indexes <stage 2 of 3>...
310310 index entries processed.
0 unindexed files processed.
CHKDSK is verifying security descriptors <stage 3 of 3>...
The security file record segment is incorrect.
Examining an index entry with id 12151 in index $SII of file 9.
Examining an index entry with id 12152 in index $SII of file 9.
Examining an index entry with id 12153 in index $SII of file 9.
Examining an index entry with id 12154 in index $SII of file 9.
Examining an index entry with id 12155 in index $SII of file 9.
Examining an index entry with id 12156 in index $SII of file 9.
Examining an index entry with id 12157 in index $SII of file 9.
Examining an index entry with id 12158 in index $SII of file 9.
Examining an index entry with id 12159 in index $SII of file 9.
Examining an index entry with id 12152 in index $SDH of file 9.
Examining an index entry with id 12151 in index $SDH of file 9.
Examining an index entry with id 12159 in index $SDH of file 9.
Examining an index entry with id 12154 in index $SDH of file 9.
Examining an index entry with id 12156 in index $SDH of file 9.
Examining an index entry with id 12155 in index $SDH of file 9.
Examining an index entry with id 12157 in index $SDH of file 9.
Examining an index entry with id 12158 in index $SDH of file 9.
Examining an index entry with id 12153 in index $SDH of file 9.
255616 security descriptors processed.
Security descriptor verification completed.
27348 data files processed.
CHKDSK is verifying Usn Journal...
The Volume Bitmap is incorrect.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
182171640 KB total disk space
86008848 KB in 7075 files.
109684 KB in 2326 indexes.
0 KB in bad sectors.
512940 KB in use by the system.
65536 KB occupied by the log file.
95540168 KB available on disk.
4096 bytes in each allocation unit.
45542910 total allocation units on disk.
23885042 allocation units available on disk.
Failed to transfer logged messages to the event log with status 50.
C:\>
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Now, here's the result I got. What's next?
C:\>chkdsk/f
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another process. Chkdsk may run if this volume is dismounted first.
ALL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID.
Would you like to force a dismount on this volume? <Y/N> y
Volume dismounted. All opened handles to this volume are now invalid.
Volume label is OS.
Volume label is OS.
797 large file records processed.
965588 index entries processed.
Index verification completed.
5 unindexed files processed.
34895024 USN bytes processed.
Usn Journal verification completed.
Windows has checked the file system and found no problems.
86418520 KB in 213556 files.
108728 KB in 27349 indexes.
366576 KB in use by the system.
95277816 KB available on disk.
23819454 allocation units available on disk.
C:\>
