With XP where laptops have both a Wireless NIC and a LAN (Wired) NIC I configure the IP settings identically except for the laptop's IP address - eg.
Wireless Adapter
IP Address: 192.168.0.21
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Preferred DNS Server: ...
Secondary DNS Server: ...
LAN Adapter
IP Address: 192.168.0.22
It is then a simple matter to switch off the Wireless Adapter & plug in an ethernet cable or unplug the cable and turn on the Wireless Adapter to switch the connection type. This has worked fine for years.
This does not seem to work for Vista. I can only have a Default Gateway on the active NIC and must make it so before I activate it otherwise I get the following error messages when trying to configure the NIC's IP settings.
"Warning - Multiple default gateways are intended to provide redundancy to a single network (such as an intranet or the internet). They will not function properly when the gateways are on two separate, disjoint networks (such as one on your intranet and one on the Internet) Do you want to save this configuration?"
If I ignore the warnings, then there is no Internet Connection. Is there any way I can achieve the simplicity that was available under Windows XP?
Any help would be appreciated.
Wireless Adapter
LAN Adapter
