Solved Copy and Paste
rissrae
Im having issues with copy and pasting, as I can't do it at all. The shortcuts wont work or anything. I think it may be an issue with left clicking on my mouse because I cannot highlight anything to get the option to copy. Ive also noticed that I cannot write emails because Im not able to click the box to type. Copy/paste is enabled, and Ive ran out of ideas of what to try. Help would be awesome!
Welcome
Try closing all windows and then rebooting
try
a different broswer
Try
and see if it works in another user account.
Try
and see if it works with another mouse
try resetting IE
Tools > Options > Advanced (tab) > under 'Reset
Internet Explorer settings' click the 'Reset'
You are very welcome. I figured if I gave you enough things to try I had to be right eventually. Good luck
