CPU Priority for Processes
How to Make a Program or Process Run with a Higher or Lower CPU Priority in Vista
This will show you how to set a Program or Process to temporarily run with a higher or lower CPU priority in Vista. The higher the priority is set for it will mean the more resources will be made available to help it run faster.
It can be helpful to tell vista how a program should receive more or less CPU priority depending on your needs. For example, this can help speed up a heavy resource demanding program temporarily to help it finish faster.
  • The CPU priority setting you make for a process will only last as long as the process is open. If you close the application (process) or restart the computer, then the CPU priority will return to normal for that process automatically.
  • This will not work on processes that are Services, programs that creates and use their own service (Ex: Antivirus), or on some Vista system files.
1. Right click on the Taskbar.​
2. Click on Task Manager.​
3. Click on the Processes tab. (See screenshot below step 5)​
4. Click on the Show processes from all users button.​
5. If prompted, click on the Continue button in the UAC prompt.​
6. Right click on the process you want to change the CPU priority level on.​
7. Click on Set Priority and then click (dot) the CPU priority level you want it to be set on. (See screenshot below)​
NOTE: Realtime is the highest CPU priority, and Low is the lowest CPU priority.
8. Click on the Change Priority button in the confirmation pop-up. (See screenshot below)​
9. Close Task Manager.​
10. Now this process will run with the cpu priority you set in step 7 until the process is closed or you log off or shutdown Vista.​
i have a question:
Why doesn't my pc let me choose Real Time priority?
And how can i solve it?
oh yeah, i also would like to get rid of the error logs...
when programs stop working, a window pops up, I would like to get rid of it.
Thanks
Hi Juca,
Welcome to the forum. :party:
What process are your try to set the Real Time Priority for?
You can disable the Windows Error Reporting Service service. This tutorial will show you how if needed.
You may also want to disable the diagnostic services to if they bug you to.
Diagnostic Policy Service
Diagnostic Service Host
Diagnostic System Host
How to Disable or Enable Vista Services With a Advice Guide
hi,can i set svchost.exe set priority low?
    Intel 2140 3.2GHz
    Intel (R) 946GZ
    2.0GB
    Intel Graphics Media Acclerato
    160GB
Hello Silent_Guardian,
Sorry, but the svchost.exe process's priority cannot be changed since it is a system process. You can right click on the svchost.exe process and click Go to Services(s) to see what it is for. They will be the highlighted ones with the same PID number.
Here's one for ya.
I have winUHA running and for some reason it won't let me change its priority, saying access is denied. I tried changing permissions for users, but that doesn't do anything.
Please help me out.
Hi Merrick,
If it is a protected process, then you will not be able to change the CPU priority for it unless there is an option for it in the program itself to set.
Sorry, :(
Merrick, that's great news. Please share if you discover how you got it to work for you.
Thank you for the feedback,
Ok well i think i found out how to set the ones that give you the access denied sign. Its actually really easy just click on show processes from all users and hit ok then you can change it. except it doesnt seem like Auslogics Disk Wiper is using any more resources... It was using 5.9K memory before and after i set it to realtime it still is using 5.9K. Well either way it works now.
    Intel Mobile Core 2 Duo P8600 @2.4GHz
    COMPAL JHL90
    4GB DDR2 6400
    Nvidia GeForce 9600M GT 512MB
Hi, is it usual for the processes to make them selfs high or low priorities? Because the process dwm.exe usually sets its self to high priority. Also when i play guild wars it sets its self to low priority and its incredibly slow! Have any ideas?
sincerely, Iceedew
Hello Iceedew, and welcome to Vista Forums.
Yes, a program can have itself set to run with a certain CPU priority by design. Some programs will even allow you to manually change the CPU priority in it's settings somewhere. For example, Auslogics Disk Defrag. (Settings, Program Settings, Defragmentation tab, CPU Usage)
Your welcome Iceedew.
If I low some of the Appli priority does it slow down in processing?
Thanks for the guide!
    Q6600 OCed till 3.3Ghz
    Nvidia XFX nForce 780i SLI
    2X2GB Corsair DDR2 800Mhz OCed @ 820Mhz
    2xNvidia 9500 GT SLI OCed @ 730Mhz each.
    Motherboard Built in
    Acer 22' LCD + 18.5 Wide Samsung LCD
    Internal 2x250 GB SATA II Maxtor, External 500GB SATA WD,
    600Watts
    GIGABYTE
    GIGABYTE Volar CPU Cooler
    Prestigio
    Samsung Pleomax
    2Mbps
Hi LightingSpeed11,
If you lower the CPU priority level for a process (program), then it will slow down or stop running if another higher priority process (program) is running until the process (program) you set is closed, you logoff, or shutdown Vista to reset the CPU priority levels back to default.
Thanks for the explanation I do understand now :)
    600Watts
    GIGABYTE
    Prestigio
    Samsung Pleomax
    2Mbps
Your welcome LightingSpeed.
Hello, I'm new and I'd just like to say your threads and guides are really good, very helpful. One question about setting the cpu priority...
Can it be, for example set to high or real time everytime the application/.exe runs?
Thanks.
Hello Carlos,
Sorry but no. Only temporarily. See the NOTE at the top of the tutorial for more details on this. :(
