Solved CPU Temperature!
zombifier
Hell Everyone...
Im Running Vista Ultimate SP2 32bit on my Acer Aspire Laptop which has a Core Duo T2350, 2GB of DDR2 RAM....
My CPU temperature when idle is around 60-65 degrees C. However, when i run any 3D programs or 3D games my CPU temperature jumps up to 85-92 Degrees C. is that normal, or should i get my laptop Checked out?? please help me out...
Thnx..
Extra Info.
Core Clock: 1862.24 MHz
Thorttle: 1862.24 MHz
FID: 14.0x
VID: 1.2625V
    Acer Aspire 9410
    Core Duo T2350
    MyALL
    2GB
    nVIDIA GeForce Go 7300
    17.1" LCD
    1440*900
    Hitachi 120GB 5400RPM Toshiba 160GB 7400RPM
    512 Cable
Hello zombifier,
That does seem to be a bit hot, but in your part of the world its going to get hot.
I would clean all the vents and make sure the system fan is working OK.
Another option is to get a Laptop cool mat, this will reduce the temperature.
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Thanks for your help Stuart... There is something that i tried.. and i think it worked, changing the game options to run in Direct3D rather than OpenGL. the CPU temperature dropped from 96 C. to 78 C.
Whats the secret? I cant tell :P
whats the difference between OpenGL and Direct3D?
anywayz, thanks a lot for your help brother :)
    Acer Aspire 9410
    Core Duo T2350
    MyALL
    2GB
    17.1" LCD
    1440*900
    512 Cable
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
