Cpu
Feindflug
Hi, most of the time the CPU-meter tells me that it works around 50-55%, even when the no programs are running except the explorer. I don't think that this is normal, nor healthy for the computer. Once in a while, when I start the computer, I'm surprised to see that the computer works with the CPU being around 5-10%. But this happens rarely, and as said most of the time the computer is around 50%, and as soon as I open one program, it goes up into the 90s and often even blocks at 100%.
What can be the cause for this, and is there a remedy?
Thanks!
    Intel 2 GHz
    dunno what that is, but it was changed.
    3 gig
Thanks!
Hi Feindflug..... welcome to the forum ;)
open ''task manager'' (ctrl-alt-delete), & look for the process using the most processing power, then take a screen shot & post it back for us.
i had this same problem on a build once, it had me running in circles..... but it turned out to be a PCI card that the motherboard didn't like :(
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
I don't know how to take a screen shot, but the task manager tells that explorer is the culprit. When the CPU is at 50-55%, explorer takes around 45-47% of that.
    Intel 2 GHz
    3 gig
hello:
---it may also be 'malware, spyware' since these programs will be active in the background while you are browsing---(clearing these out usually fixes the prob)---
---maybe try Ccleaner--->CCleaner - Home---
---or try malware remove--->Downloads | Remove-Malware.com---
---please post your results---thank you---
peace
    eMachines D620 (laptop)
    AMD Athlon Processor 2650e 1.60GHz
    ACPI x86-based PC
    (RAM) 1.00GB
    Internal DAC (400MHz) - memory: 382 MB
    Realtek High Def Audio
    ATI Radeon X1250 - 14"
    1280 x 800 (60Hz)
    ST9160310AS ATA Device
    Stealth~graphite
    Synaptics PS/2 Port Touchpad + Microsoft Optical Mouse 500
    Launch Manager Version 2.0.02
    Cable/wireless-router
    NO WEBCAM - (privacy)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
An over-active explorer.exe usually can point to malware etc. To add to kikidee's post, you could try an AV like Avast:
Free antivirus software download
hello:
---yes---I also use the free-online anti-virus 'Avast'---
---some people also recommend another free-online a/v - Avira - which has better ratings---
peace
    ACPI x86-based PC
    (RAM) 1.00GB
    1280 x 800 (60Hz)
    Stealth~graphite
Hi, thnx for the advice. I reformatted/recovered the computer just last week, and have Norton active. Is it possible that malware/spyware could have gotten on the computer in such a short time? Also, since I've Norton, could I still install one of your recomended programs?
    Intel 2 GHz
    3 gig
hello:
---what I did with my pc---download the 'anti-virus' (of your choice) first, but do not open yet--->uninstall the Norton (allow restart)--->now find the antivirus-program and open/install---done---
---also---when you download any 'defender/firewall' program also - do as above - (uncheck the options under Windows-programs to OFF)---
peace
    ACPI x86-based PC
    (RAM) 1.00GB
    1280 x 800 (60Hz)
    Stealth~graphite
Are the antivirus programs you recommend comparable to Norton or McAfee? I thought they were superior to free anti-virus programs. Also, must the problem be malware/spyware, or can it be caused by the graphic card too? For example, if I use wikipedia or gmail, the computer becomes unusable. If use facebook or yahoo mail no problems occur.
    Intel 2 GHz
    3 gig
They A/V's are very comparable. Paid does not always mean better ;)
malware/virus can be one of many potential issues, but it's always a good place to begin.
Video driver problems seem highly unlikely considering the symptoms.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
