critical system driver hdhroftl.sys
cre
Posts
2
On my laptop, I ran my recovery CD a couple times without luck. Safe mode and last known configuration do not work either.
The startup screen says I'm missing system32/drivers/hdhroftl.sys
I can't find this file on my desktop PC and google turns up no results - it sounds like a file which I don't really need but maybe a virus or spyware changed my system config. Is there anything I can do?
tom982
٩(͡๏̯͡๏)۶
England
Posts
3,642
Hello cre and welcome to the forums :party:
Try booting from the Vista disc and then doing a system restore to before you started experiencing the problem.
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Posts
99
right click on the folder drivers then select "restore a prevous version" select an earlier version of the folder and open and select the file then right click and "restore" or "copy" to a safe place to work with.
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
pugmama05
Posts
18
i would love to know how this turns out, sounding very familiar, however i can't do anything with the replies here, they didn't work, don't have recovery or full os disk.
tom982
٩(͡๏̯͡๏)۶
England
Posts
3,642
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
cre
Posts
2
hey pug, i couldn't even get into windows to restore and i didn't have a disk, so i just reinstalled xp instead of keeping my vista.
restore to last working configuration didn't work either from the boot menu
i still haven't found out what hdhroftl.sys is and where i got it from.
