customising right click menu
hclarkjr
Vista Pro
is there a tutorial on making a custom right click menu like i have posted a picture of?
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM, WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
One must use Regedit for such things. Run (WinKey + R) Regedit and navigate to HKEY_CLASSES_ROOT\Directory\Background\shell. Under shell create a new key with a miscellaneous name (e.g. Fire1) and set its value (in the right pane) to the name you wish the item to have (e.g. Firefox.) Then create a new key under it, named command, and this time set its value to the exact path of the target executable. Remember to experiment.
The result:
To set some of the items in that image, it is a little more complicated. I would recommend you query these individually. To add the control panel for example, one would create the following structure: HKEY_CLASSES_ROOT\Directory\Background\shell\Control Panel\command and set command's value to rundll32.exe shell32.dll,Control_RunDLL.
For more information see the following
tutorial I just found.
    Dell Dimension 9200
    Intel Core 2 Duo 2.66 GHz
    2.00 GB
    Nvidia 8600 GTS (Overclocked)
    Dell 2007 WFP 27 in LCD
    1680 x 1050
    One (72.8/455 GB)
    Razer Salmosa
    Standard Dell Keyboard (Dusty)
thank you
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
I believe there is a freeware program called FileMenu Tools that has a comfortable interface to modify and customize the context menu for explorer and perhaps some other interfaces.
    HP dv5-1120ej Notebook PC
    Intel Dual 2.16GHz
    NVidia GeForce 9200M GS, 256MB
    320GB internal, 320GB external, 1TB external to come (big download library XD)
    Fast enough
    Firefox, Foobar, and AutoHotkey! Go open source!
thank you
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Viewsonic VG2230wm
    1680X1050
    comcast 16mb\second
