D drive problem!
kiranrasaily
Hi members,
Greetings!
I have come across a problem with my dell laptop. My hard disc is partitioned into C and D. My D drive is almost full but everytime i try to open it shows only two folders, Recovary and Boot. Where are other folders gone? I deleted those two folders and tried and again opened D drive...which reads" This folder is empty" where as the space is almost full.
Please help me how can i have all my folders in D drive.
Thank you.
Kiran
Hi kiranrasaily,
Welcome to Vista Forums!
Did this recently/suddenly happen? Do you know when this problem began? Try a System Restore to a point in time BEFORE the problem began. Here's the procedure: http://www.vistax64.com/tutorials/76905-system-restore-how.html. Be sure to check the box to show more than 5 days of restore points. If the first attempt fails, then try an earlier point or two. NOTE: You will have to re-install any software and updates you installed between now and the restore point, but you can use Windows Update for the updates.
If that doesn't work, go to Start / Control Panel / Folder Options / View and check the button to show hidden files files and folders, uncheck the box to hide system files, and uncheck the box to hide extensions of known file types (not all of these are required here, but they are good changes to make for other reasons while you are making changes anyway). Then check D:\ and see if you can now see anything.
Go to D:\ and right click on it and click on properties and then click on security. Make sure you are listed with full rights. If not, add yourself with full rights. Click on Advanced and do the same thing in the lower Special Permissions section (make sure you check the box to apply it to all sub-directories and files). Then click on the Ownership Tab and make yourself the Owner of the Drive (and again check the box to apply it to all sub-directories and files). Now check D:\ and see if you can see any changes.
If not, go to Start / Control Panel / Administrative Tools / Computer Management / Disk Management and take screenshot of that page, save it as a .jpg file, and attach it to your next reply. This is easier than me asking you a hundred questions about what it says.
Do you have Manufacturer Recovery Disks or a Vista Installation Disk? If not, by deleting Recovery you deleted your ability to restore the system to factory conditions if that ever becomes necessary. You may need to purchase recovery disks from Dell unless you already made some. I will provide more information about this once I know more about your specific computer.
So I can check your system better and knowing it is a Dell, please include the Service Tag Number in your next reply - I'd like to know more about your hard drive and your system configuration and this will give me the details of your specific computer.
Go to Start / All Programs / Accessories / Command Prompt and right click on command prompt and click Run as Administrator.
Type chkdsk /f /r and enter. It will ask if you want to do so at the next reboot. Say yes and then reboot to run it. When done, do the same thing again but this time type chkdsk D: /f /r and enter. Again let it run until it is completed. Check D:\ to see if that helped.
I will provide further instructions to test the drive and partition once I have the information about the computer and can determine what diagnostic options are available and where I can find other hard drive diagnostic software.
I hope this helps and await your reply so I can provide additional suggestions specific to your computer and perhaps understand what is happening with D:\ from the screenshot.
Good luck!
    1920 x 1200 pixels
Thank you for instructions...but that did not work. At last when i tried with the chkdsk d/f/r...it said access deniedas you do not have sufficient priviledges. Please help me I have some important document in D
Thank you.
Kiran
Hi Kiran,
System Restore did not work? Why not? Could you not go back far enough or do you have no restore points?
Did you follow all the prior instructions including changing the permissions and ownership?
Where is the Service Tag number?
Where is the screenshot from Disk Management?
I need your help to help you. I need to understand what happened with each of the steps I recommended - not just the one. Without the information I requested and you doing the steps I recommended, I cannot help you as well as I can if you do those steps, answer my questions, provide me with information or screenshots I've requested, explain how each procedure went and any problems you had or why they didn't work, and tell me everything that happened. I need what I've requested before I can proceed any further.
Thanks and good luck!
    1920 x 1200 pixels
Dear Lorien, how nice of you to reply my post. Thank you for your efforts on helping me solve my problem. I had a few restore points and that did not work.
Then i went to second options: show hidden files/folders...this also did not work.
i hv attached the screen shot for your reference. Service Tag number is HSZD2H1.
Systen Confic: Model 1525, Vista home Basic sp2, Processor:Inter(R)Pentium(R)Dual CPU T2390 @ 1.86GHZ 1.86GHZ, Memory:3.00 GB, OS 32bit.
For your kind information, i have Vista Inst Disk Sp1.
Thank you.
Regards
Kiran
