Data Execution Prevention and Fire Fox 13.0
JimJoe
When I had FF 3.x a few months ago, I didn't have problems with DEP, which left FF3.x alone.
Some web sites I go to started popping up that I had an obsolete version of FF and I needed to upgrade.
So I did so.
Since then DEP has been freaking out over FF.
It won't let me allow Ff and its plugin container to operate. As far as I know, all plugins are up to date.
I have scanned my cmoputer for visruses and trojans, none there. i have AVG paid and malwarebytes paid. Both up to date.
How do I fix this ... before I either heave my computer into the dumpster or format it and convert it to a Linux computer ?
Thanks.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
I have disabled 3 old plugins and removed another 2. If that doesn't solve it, what then ?
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
Hello Jim,
I'd recommend to completely uninstall Firefox, download a clean copy from Mozilla at the link below, and reinstall. You may have gotten a bad copy if you updated from a website instead of the source Mozilla.
Mozilla Firefox Web Browser
I downloaded from Mozilla. I'll do it again.
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
They patched it, FF is now at 13.0.1 I unnistaleld 13.0, and downloaded 13.0.1 via Chrome and installed it.
Sigh and when I went to mozilla.org to check my add-ons, their web site diosabled Java. said 1.6 was too old. Now I have 1.7, and I have heard bad things about it... I've had to use more than one version one the same computer so I don't see the problem. I rarely use Java at home.
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
Hopefully 1.7 will not be bad for you.
Hopefully. Hm... I used 'the glare' on my computer... maybe I hurt its electrons or something.
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
LOL
what version of adobe flash are ya running? I had the same exact DEP error.. and it was only after a flash update..
    laptop: hp pavillion dv6-1250us
    intel core 2 duo p7350 @2.0ghz 2.0ghz
    unknown
    4gb
    intel graphics media acellerator
    idt pc audio
    inbuilt laptop screen
    1366x768
    1@500gb
    fios 15/5 lowest level tier.
    browsers: mozilla firefox google chrome
active x version and plugin version same.
11.3.300.265
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
first try upgrading to the newest stable flash. if it still gives you grief... I'll post a link to older versions which also has instructions on downgrading.
    unknown
    4gb
    idt pc audio
    1366x768
    1@500gb
It hasn't done it this week.
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
you try provoking a response.. by say.. playing a bunch of youtube videos?
heres hoping it doesnt come back.
    unknown
    4gb
    idt pc audio
    1366x768
    1@500gb
