This is actually a question about Win 7, but I'm fairly sure it works the same way in Vista.
When you open my computer and double-click on something, (say a game CD) the default action is always to run an installer or setup or something. I want to change it so that instead, it opens the CD and let's me browse the files. I'm not talking about AutoPlay, I don't want that annoying popup every time I put something in. I just want it to Open instead of Run when I double click it, it's annoying to have to do a Right Click > Open each time. I know on my Vista machine it does this, but I can't remember if I did something to set it up like that or not, or what I did to set it up if I did. Anyone know how? Thanks
- Dell Inspiron 1545
- Intel Core 2 Duo T6400 @ 2.00 GHz
- DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
- 4 GB
- Mobile Intel(R) 4 Series Express Chipset Family
- IDT High Definition Audio CODEC
- Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
- 1366x768
- Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
- Cooling
- Single built in fan
- Touchpad, + Logitech wireless mouse (USB)
- Built in
- ~150 kilobytes/sec DL
- Other Info
- Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
