Default font in Vista - Problem
CustomVis
Hi guys,
I downloaded some new Mac fonts and I want to change the default font in Vista to one of them. I can't do that via Appearance>Advanced, because there's a limited variety of fonts to choose from.
Help? :)
Hello CustomVis, and welcome to Vista Forums.
Did you save the font in the C:\Windows\Fonts folder? It should appear in the Advanced Appearance settings as font to select if you did and the font is supported by Vista.
And yes, I did install it and it does not appear in there (quite interesting actually - I downloaded other custom fonts months ago and they don't appear there, too). The only fonts I can choose from are:
I rebooted and it doesn't seem to do anything (the reg edit) :huh:
Update: it did change some small things but the main font remains unchanged :(
Without then also being changed in Advanced Settings, it will not change all of the default fonts. :(
Can you upload the font that you are trying? I'll also test it on my system to see if it may just be an issue on your computer or not.
