Solved Default Programs page will not load
The only way I know of to do imaging requires windows to not be running so if I am right you have to get a version of acronis that allows you to boot into the disk. Now I haven't actually used acronis but I suspect that it is necessary to shut down windows since with an image every file is copied. To my knowledge this can't be done with windows running.
As for stopping tasks if you don't know what the program is you should google it. For example I googled pcalua.exe and found that it is the program compatibility assistant.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Acronis states that it can do a sector-by-sector backup with or without blank sectors and this is considered an image. They also stated that a Disks/Partitions backup will also backup the operating system and can be restored to a working state. The only thing that can't restore a working operating system seems to be a simple File backup where you choose the files.
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech K350 Wireless Keyboard
    Logitech M705 Wireless Mouse
I did the image with Acronis. Then I set it up to do incremental backups every week and a new image every month.
I'm still having problems with the Partition Table being recognized, but that's a discussion for a different thread.
    AMD
    ASUS M3A78-EM
Just thought i'd mention that you can image your operating system while it's running with Macrium Reflect so, it shouldn't be any different in Acronis.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
