Solved Default Settings
Wan123
Hi Everybody!! I recently messed up real bad. I was playing Tiger Woods PGA Tour 08 for PC. And I went into the documents folder to try to delete the last saved game. When I did I made a mistake and changed the folder with a GCF file in it to open the GCF files with adobe reader. Now I can't figure out what program it originally was suppose to open with. So my question is: How do I change the GCF file folder back to it's default settings so it will open with the program that it's suppose to open with?
Hello Wan, and welcome to Vista Forums.
If this helps, this is what I found for this:
Valve Corporation uses .GCF games cache files both with its Steam computer game online content delivery platform (used for downloading computer games and content from the Internet), and with its Source 3D game engine (used to render realistic 3D graphics in their games). Valve Corporation also developed the game Half-life (along with its sequels) and the .GCF files is sometimes specifically associated with this game, although it is entirely possible that .GCF might be generated by any of Valve Corporation's games..
If you have Half-Life or another Valve brand game, then reinstalling the game to repair it without uninstalling it should fix the file association also.
Thanks Shawn!! That helped alot!! I don't have Half-Life. But it worked for Tiger Woods PGA Tour 08 too. It actually fixed the problem like you said. Thanks alot for your feedback!! Have a blessed one!!
You're welcome Wan. I'm happy to hear that you got it sorted. :)
