Dell 530 OC help
venom762
I have a stock dell 530 with q6600 CPU and a 0FM586 MoBo, should I OC and will it be safe with stock cooling? I went into the bios (phoenix 1.0.16) and there is no MIT setting.
    Dell Inspiron 530
    Intel Core 2 quad Q6600 2.40GHz
    OFM586
    3.5GB DDR2 at 667MHz
    19inch dell HD flatscreen
    1280x768 60hz
    7mb
Hi venom762 ...welcome to the x64 forums ;)
you cant OC a dell my friend, the BIOS is locked down to prevent tampering.....
the ONLY way possible to OC it would be through windows :( via a few dedicated apps..... I DO NOT RECOMMEND THIS!!
the problem you'll have is even though we may find you an app capable of upping your FSB, the board itself has no voltage control, so it will become unstable very quickly...
TBH if you wanna OC, grab a new 775 mobo, remove your Q6600 & replace with a cheapo C2D & build a dedicated OCing rig....
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
yep, grab a new mobo if you want to OC.
Overclocking is not reccomeded with stock coolong either mate.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Thank you it looks like a good forum, and I did not know this thank you for the help.
    Dell Inspiron 530
    OFM586
    1280x768 60hz
    7mb
No problems :)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Inspiron 530 is a failure . . . Dont even try to mess up with this computer. It will give you nothing but problems. Its outtta my experience as i work for Dell. Let the computer run as it is! Mark my words...:rolleyes:
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Hi venom. The dell 530 with the q6600 is a great overclocker, sorry you guys are unfamiliar with it.
There's a totally easy tape method similar to the old amd 'tape over the pin' method.
Here's a good tutorial with pics. enjoy
Dell Inspiron 530 Core2Quad q6600 minitower cheap overclocking - success!
if your talking about a BSEL MOD, its a lot of fiddling around for a pretty small FSB jump....IMO
though i'd certainly prefer ppl used this method than using OC S/W to change BIOS settings, this method ALWAYS ends in disaster....
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
Thats the one...
Ups the fsb to 1333 from 1066...
Personally....
I wouldnt. But apparently its safe.
    My build
    Core2Quad Q9550 yorkfield C1 3.8G
    GIGABYTE GA-EP45-UD3R
    8gig Kingston HyperX 8500 CL5
    Gigabyte GTX280 1G...generally stock.
    onboard
    Samsung 24" 2433bw + Benq 19" FP91G+
    2 x Samsung 500G Raid0 1 x Samsung 1TB 32
    Thermaltake Toughpower 850W
    Antec twelve hundred.
    Air...a lot of air. Thermalright 120 push/pull,8 case fans,
    Logitech G5
    Logitech G15
    ADSL2
