Desperate help needed
lugidees
my gf and i broke up and she left me the lap top i bought her. all my pics and some work and music are on there. I need to get in but i dont have the password and my x moved out east somewhere. its stuck on her profile to log in and i cant pick any other users. how can i get in to save my personal stuff? i just wanna burn my stuff them format the comp
Hit F8 and log in via safe mode..... "it should be non password protected" now you should be able to edit the account and remove the password
just edit the account and remove password
if safe mode has a password then you will have to wait to see if any1 ells has a solution
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
As long as she didnt use file encryption you can bypass the user log-in and access all files.
download Simply MEPIS 3.3 here:
> Download MEPIS - LQ ISO
Step1
Burn it to CD as an ISO image (ISO is a disk image. for free ISO image burning software):
ISO Recorder v3
to burn ISO right click downloaded ISO file and option to burn ISO image will be available with the above software. Nero users will find ISO image burning as program feature, and can add the downloaded file for burning.
Step2
Boot from the CD drive, put Linux CD in drive and boot. It will run Simply MEPIS from the CD, but it will not install
Step34
Sign in as: root, password: root
This will give you access to the drive and all folders.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
