disabled power/sleep button in start menu
tinschel
I've disabled the power/sleep button in the start menu a while ago to prevent my children from shutting down the computer. Now they are older and I want to get them to put the computer to sleep when they are not using it. Unfortunately, I can not remember how I disabled the power button. There are no group policies set and I couldn't find any settings on the registry (as suggested in your tutorials http://www.vistax64.com/tutorials/68146-power-button.html and http://www.vistax64.com/tutorials/105003-shutdown-options-start-menu.html). Here is a screenshot of the situation:
https://www.nirvanaware.com/browser/home/public.public/disabledPower.jpg
Any ideas how I could enable this again?
    Intel Core 2 Quad 2.4GHz
    2GB
    Logitech MX Master 4
Hi Brink!
Thanks for the quick response! Unfortunately I don't have a key "Power" under either "HKey_Local_Machine\Software\Policies\Microsoft" or "HKey_Local_Machine\Software\Policies". So there is nothing I can delete. I did notice that there are several different "PowerSettings" keys within my registry but I can't make any sense out of their sub-keys. Any other ideas?
Tino
    2GB
Tino,
You might look through the Local Group Policy Editor settings at Computer Configuration, Administrative Templates, System, and Power Management. You may have a setting enabled here that is causing this.
Shawn: thanks for you help. After many hours of searching through the group policy editor and switching accounts, it turned out to be the following group policy:
Computer Configuration / Windows Settings / Security Settings / Local Policies / User Rights Assignment / Shut down the system
Who is supposed to keep track of all these policies? Thanks again for your help and take care!
Tino
    2GB
Tino, I'm glad to hear that you got it sorted out. Wow, that was buried in there.
