Disabling all Power Management?
TBolt
Hi, Brink et al. :)
I experience a lot of warping in an online game that I play now and then, Aces High II. My system has plenty of RAM (4GB) and a good mobile GPU; so, I know the problem is caused by something else.
I have disabled all unnecessary services, per blackviper.com.
The tech guy at the game company said that I need to "disable all power management" because it is the main source of warping online. Hmmm...ok. I'm willing to give it a try.
I searched the forums; this thread is the closest thing I found about disabling all power management in Vista. Didn't really give me what I'm looking for.
I was surprised that there isn't a Service in Administrative Tools > Services that I can just disable.
Any idea how I might disable all power management in Vista Home Premium -- at least, temporarily while I see if it makes a difference?
Thank you!!! :)
My system, in case it matters:
Gateway P-6860Fx laptop
Processor: Intel(R) Core(TM)2 Duo CPU T5550 @ 1.83GHz (2 CPUs), ~1.8GHz
Memory: 4094MB RAM
Page File: 1110MB used, 7251MB available
Card name: NVIDIA GeForce 8800M GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800M GTS
Display Memory: 2266 MB
Dedicated Memory: 475 MB
Shared Memory: 1791 MB
    Gateway P-6860fx
    Intel Core2 Duo 1.83GHz
    Cable
Hello TBbolt,
Setting everything in your Power Plan Options and Screen Saver settings to Never should turn off this for you.
Okay...thanks, Brink. I'll use the "High Performance" power level as a base and adjust from there.
    Gateway P-6860fx
    Cable
You're welcome TBolt. :)
