Disappearing of LOW folder inside Temp problem
VistaKing
Banned
Everytime I use Auslogics Disk Defrag (newiest version 1.4.16.308) the LOW folder inside C:\Users\(username)\AppData\Local\Temp keeps disappearing not allowing me to print from Internet Explorer. I keep having to type this in " icacls C:\Users\(username)\AppData\Local\Temp\Low /setintegritylevel (OI)(CI) low " in the command prompt.
I use O&O defrag Pro 10. It does not remove temp files on defrag. Try a different program.
    16GB DDR667
    SAS RAID
Hi VistaKing,
This is a default setting in Auslogics Disk Defrag. To stop it:
1. Click on the Settings link at the top right corner and click on Program Settings.
2. Click on the Defragmentation tab.
3. Uncheck the Remove temp. files before defragmentation box.
4. Click OK.
