Disk drive help please
mccord
My disk drive won't read all disks. I can no longer burn disks nor can I open pictures that I've saved to disks. I can play some movies, but I found I had to clean some before they would play. Some still don't play even if cleaned. Is it dying or is there something I can do? I have an HP Pavilion laptop.
Thanks!
    HP Pavilion dv4
Welcome
First thing is to check the drivers
Go to search and type device manager. In device manager make sure that there are no small yellow triangles. If there are not any seen, update the dvd/ cd drivers and disc drives.
Make sure you have all the Vista SPs and everything is up to date
http://support.microsoft.com/kb/929461
You could also try very carefully cleaning the pick up with a little isopropyl alcohol on a cotton bud. VERY CAREFULLY MIND.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
